Question about Husqvarna Garden
Motor slows & stops within minutes use - Husqvarna Garden
  • Husqvarna Master
  • 1,807 Answers
What model, please give as much detail as possible.
Posted on Aug 02, 2013
We have a proform crosswalk advanced 525 and everytime I get on it will shut off within 3 to 5 minutes of starting. The power will not go off. Only the belt stops and I will have to restart the treadmill...
Most likely your problem can be with the motor control board, with the kids, the motor is not pull many amps, so the treadmill will operate normally. Replace the Motor control board
Feb 28, 2015 | Proform Exercise & Fitness
Why does the blower motor slow to a stop a few minutes after turning it on?
Blower Resistor pack going bad or motor bearings seizing .
Jul 28, 2014 | 1992 Chevrolet Caprice
Proform C950 intermittently stops working shortly after start
please see the video attached. lube the rollers bearing front+ back
2) test the input terminal voltage motor, if there ARE the motor is faulty. see my personal TIPS for motor help 3) test the output voltage board, if there ARE NOT voltage for input voltage MOTOR, the board is faulty.
God bless you
Nov 27, 2013 | Proform C950 Treadmill Walking Belt
Sewing machine stops sews a minute slows down or stops then starts up
I suggest having the machine checked at a sewing machine shop
to see if there is something wrong with the motor, or the foot pedal
but first check to make sure the power cord & foot pedal are
connected correctly
Aug 20, 2012 | Singer Sewing Machines
My 1998 Deville has issues with the traction control sensors i think. the system will react almost always in a slow left turn but lately does it at straight highway speed. it started some time ago, i
Water Pump & Motor Mounts have nothing to do with
any Check Light Issues,where did you come up with that?
You always check for codes within a day or two, of any
light you get on your dash & then have those code related
issues diagnosed & repaired in 3 or 4 days
Otherwise stop using any vehicle before you cause
some damaged
Traction Control is part of the ABS Braking System
Don't use it until repaired
Jul 24, 2012 | 1998 Cadillac DeVille
New compressor, when i turn it on it spins fast for 5- 10 seconds then slows down til it stops completely,oil is full,reset button on motor does not trip nor does my 50 amp breaker, i put voltmeter on...
Try tightening the drive belt first. As pressure builds a loose belt will start slipping and slows down . It will eventually stop if not cut off!! If this is not the problem remove the drive belt and run the motor 5 minutes or so and see if it runs OK. While the belt is off and motor not running turn the compressor by hand. If it hard to rotate it may be bad. .I have seen both bad motors and pumps from the factory on new units. It's very seldom it happens but can and has.Also look on the fly wheel. Their should be an arrow showing correct rotation. Make sure rotation is correct. since it is 1 ph it should be. If motor or compressor is bad there should be an 800 # on the tank. Give it a call or call your nearest IR distributor.You can also call the 800 # and talk with someone in tech support.
Jul 07, 2011 | Ingersoll Air Tools & Compressors
Heater blower motor blows normal then slows down 1999 grand marquis
There is a blower resister within the blower fan that is replacable. Most likely this is the problem
Jan 04, 2010 | 1999 Mercury Grand Marquis
Ld flashes
long drain... something is obstructing or otherwise slowing down or stopping the drain process from completing within the 5 minutes allowed..
you can push stop/cancel to clear..
there may be something blocking the flow of water through the pump, you could disassemble and check and clear if possible, or if pumps not turning and shot replace.. 285990 - Motor-Pump
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Slow fan on Window Air conditioner Sears 106.73220
if the motor seems like its getting extremely hot it could possibly be seezing up. i would suggest taking your volate reading for the motor and check for proper voltage, also check you amp draw on the motor. the proper amp draw should be on the name plat of the motor. any below the proper amp draw, replace the motor.
Apr 23, 2009 | Heating & Cooling
Garden Logo
71 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
