Do I need a driver for Durabrand 2.0 CH USB powered speaker system?
  • Shabbir  Dole
    Shabbir Dole May 11, 2010
    Well does your speaker system work when connected? Or doesn't it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Does you speaker work when connected?
Posted on Apr 28, 2008
You have to use Realtek AC 97 audio drive
Posted on Sep 19, 2008
    Genius:
  • 3,587 Answers
Maybe..who's sound card you using?
Posted on Apr 27, 2008
My usb powered speakers light up but my system still shows no audio device present
Hi, well windows must install the correct Drivers before your device will work. You need to check this.
As the speakers are powered by the USB port and require 5 volts to operate. Some USB ports do not have a full 5 volts DC and have current limiting. Your speakers may require more power then your USB ports can give. or try them with a Powered Hub.
Have you tried them in another computer? to see if they actually work?
Try, another USB port, try a powered hub.
Ensure that they show up in device manager, if there right click, and select upgrade Drivers, allow it to look for and install the generic driver.
make sure it is set as your Default device.
You may have to disable your onboard sound from the BIOS, first too.
Aug 29, 2010 | Durabrand Audio Players & Recorders
Durabrand 2.0 CH USB Speaker System
Try this, go to control panel and double click Sounds and Audio Devices. Then click advanced, under speaker settings and make sure your settings are desktop speakers. Also, in control panel, click Sound Effect Manager and do a speaker test. This should help.
Jan 20, 2009 | Audio Players & Recorders
2.0 CH USB Powered speaker System
yes.. in those types of speaker systems the usb is for just power.. and the "banana plug" is the audio jack.. there should be some kind of audio outpu on your computer .. it is usually located in the back near the middle or bottom.
Jan 09, 2009 | Durabrand DUR7 Portable DVD Player
DURABRAND 2.0 CH USB COMPUTER SPEAKERS
try going to control panel, the system icon, hardware tab, divice manager, check to see if your sound card does not have a yellow ! icon next to it, if it does try right click, go to properties, and reinstalling it, it does help if the computer is hooked to the internet so it can find it automaticly over the internet.
Aug 29, 2008 | Durabrand 5.1 Surround Sound Computer...
No audio device detected
Ok when you plugged in the USB sound did it "see" it... did it ask for "Drivers" Because this device MUST have drivers.. also ya may have to disable any onboard sound device ya may have via the BIOS setup menu. Generally these USB sound devices are real easy to install and use.. try it on another PC to be sure it is OK.. GL
Jun 05, 2008 | Durabrand 5.1 Surround Sound Computer...
Can't get my durabrand uc-280 computer spreakers to work
Returned the durabrand uc-280 to Walmart! Plugged the existing speaker into the correct hole in my new sound card. Problem solved!
Feb 16, 2008 | Audio Players & Recorders
Speaker won't work
Sija
First things First:
1) check your connectors back on the PC, I presume you use windows XP and sound drivers installed **
2) plug the speakers cable on back or front of your PC in the green (usually) connector.
3) see if sound is NOT mute on mixer , multimedia in control panel.**
4) If you can Enter your BIOS, try to enable sound, for onboard sound, if apply**
good Luck
Jan 20, 2008 | Audio Players & Recorders
Problem with speakers
if you have done a system recovery, then disconnect it, reconnect and reinstall everything of speaker. drivers, reconfigure it, will be as new again.
Dec 09, 2007 | Audio Players & Recorders
Durabrand 2.0 CH USB Powered Speaker System
Balance needs to be set up; ie, the individual channels need to be adjusted to properly hear your tunes.....accordianman
Oct 30, 2007 | Denon AVR-987 Receiver
Hi, Based on your post/description, the Durabrand 2.0 CH USB Speaker System is a basic external speaker that plugs into your PC's speaker/headset output (green jack). It is supposed to get its power from the +5VDC supplied by the USB port. Some USB port have current limiting therefore it can be anywhere from 10 - 500 mA. The power requirement of your external Durabrand speaker maybe beyond what the PC's USB ports can supply. It does not need to be recognized by the OS since it only connects to the USB to get power but there is no data interaction. Perhaps what you can do is get an external +5VDC power supply whose output is in USB type connector. The current rating would depend on the requirement of your speaker. Offhand, if the speakers are not that big, probably a 1 Amp would do. This is of course assuming that the Durabrand speaker system is fully functional. If with an external power supply it is still a no go and you have verified that sound do come out of your green jack (with the use of an ordinary headset), then the Durabrand is defective. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 22, 2007 | Denon AVR-987 Receiver
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
