Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Memory card error shows everytime camera is on
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 23, 2010
What is ERROR 32 in below camera ?
Sure it is not error 23? 32 is not on my list, but perhaps I should update that one. For Err 23 stands Too many images. Most of the time the camera can't find space on the memory card for more images. When you only have one card, see what images you can save on a computer, and then delete them from the card.
then check again.
Feb 26, 2015 | Canon PowerShot A3100 IS Digital Camera
Memory card error
It is possible the memory card is faulty, the only way to find out is replace the card.
Jun 17, 2012 | Canon PowerShot SD1300 IS IXUS 105...
Memory card error
From your menu/settings, format the card while it's in the camera and this may correct the issue you're having.
Jan 06, 2012 | Cameras
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Memory card error
Usually, this means you need to format the card in the camera before using. This completely erases the card and optimizes it for the camera.
Sep 12, 2009 | Canon PowerShot A550 Digital Camera
Sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
Memory card error/card locked
I don't know for sure, but since it is "grayed out," it MAY be that your camera can';t utilize a card that big (in gig's that is.)
Just a guess.
Mar 13, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory Card Error
Check in the Manual that the camera can accept 2Gb.
If it say it can then return the card for replacement.
Feb 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Memory Card Error
format the memory card by using low level format in your camera itself.
it must work. check out and reply the rating
Dec 27, 2007 | Pentax Optio M40 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
