Question about Saniflo & Saniplus& Macerator Pump
Macerator keeps going off even when not flushed.
    Scholar:
  • Saniflo Expert
  • 115 Answers
Water pressure makes the unit turn on and off. It will only activate on it's own when enough water pressure is present. Most likely it can be water leaking from the toilet tank into the bowl, and from the bowl into the pump. Or could also be that waste water is slowly draining back into the pump through the check valve on the discharge elbow, creating enough water pressure that it will make the unit kick on and off.
Posted on Aug 25, 2010
5 Suggested Answers
  • 16523 Answers
SOURCE: Macerator keeps runing even when there has been no
check level in tank may be to high and not shutting off valve /sticking fill valve /or flapper needs replacing
Posted on Jun 24, 2010
  • 82 Answers
SOURCE: saniflow keeps on macerating after flushing
Sounds like a stuck float switch .. probably due to gunk inside the macerator. You'll need to empty all of the water out of the WC, cisterm, isolate the electricity and disconnect the saniflo (i.e. take out WC and cistern), open up the saniflo and give it a good clean
Good luck
Posted on Jan 17, 2010
SOURCE: I have a toilet with
This seems like a problem with your cistern and not your macerator - I have a similar set up and if your push button is stuck you need to check the mechanism in the cistern - also you should have an overflow that drains into your loo within the cistern so you should check this for blockages as well.
Posted on Oct 20, 2010
  • 26 Answers
SOURCE: Whining noise after the flush is filled and the
sounds like there could be a blockage inside which is effecting the pump or the float switch look on the saniflo website for instructions how to clean etc or phone there tec department
Posted on Dec 09, 2010
Macerator assembly goes clunk when I hit the switch and at the same time the pump flushes the toilet contents. What is making the lound clunk sound, would it be a macerator assembly part?
Probably something solid stuck in the blades. If you have children then it is possible that something that is not cuttable has been flushed and is between the blades.
Jul 29, 2013 | ITT Jabsco Macerator Pump MotorPump...
LEAK AND SMELL
question aint clear.what do you want? this is in relation to plumbing and drainage however try to use ordinary instruments like gauze wire to filter the water so as to stop the blacking and you can use a rubber to hold the outlet pipe that pushes into the top of the macerator box.try it
Nov 20, 2012 | Saniflo & Saniplus& Macerator Pump
I have just installed today and when flushing toilet the water is pumped away but the motor just keeps running and overheated then cut out
Gain access to the macerator float(s), and make sure that they operate freely. You may have some packaging or other material preventing it's correct operation.
--W/D--
Jan 19, 2011 | Saniflo & Saniplus& Macerator Pump
Whining noise after the flush is filled and the noise keeps on but if the macerator is given a gentle kick the noise stops! Do I need a new Macerator?
Dec 09, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I have a toilet with a push button flush mechanism (allowing half or full flush). The toilet has a macerator behind it. If you flush the toilet and the macerator jams, the push button stays stuck in and...
Oct 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo keeps going off when not flushed
Water pressure makes the unit turn on and off. If it turning on by itself then could be water draining back into the pump. Water could be leaking from the check valve on the discharge elbow into the pump or from the toilet tank into the bowl. Inspect the flapper on the check valve and the flapper on the flush valve.
Aug 09, 2010 | Saniflo & Saniplus& Macerator Pump
Macerator keeps runing even when there has been no flush made or any water down the waste
Jun 24, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflow keeps on macerating after flushing, and I have to isolate it from the mains
Good luck
Dec 26, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Hi there, i have got a problem with my turboflush; it seems that it struggle alot after flushing, even with a clean flush. it does make a grinding noise as well. it goes on for quite a while whereas before...
It really sounds like something that shouldn't be there is in the macerator/ejector. If you are not familiar with the internal workings, call the plumber who installed it. Best case scenario, it is just something that needs to be removed. Worst case scenario, the macerator/ejector and motor bearings are shot and need to be replaced.
Dec 21, 2009 | Saniflo & Saniplus& Macerator Pump
Pumps for a few seconds then stops & pumps again for another few seconds & so on
The toilet will flush normally and shut down. Then imediately after it has shut down, as it should, it will start up again and keep going through the flush cycle until I unplug the power going to the pump. After about ten minutes, I can plug it back in and it then will not start up again until I press the flush button.
Jul 01, 2009 | Saniflo Sanibest macerator with multiple...
Saniflo & Saniplus& Macerator Pump  Logo
1,158 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
