Question about Nintendo Wii Console
My wii light won't turn on,but everything else in the same outlet works fine. The wires and everything are connected, but the light won't turn green, and it won't turn yellow orred, it's just won't start at all
  • 5 more comments
  • memorialhame Apr 29, 2008
    My wii has been off for several months, and now we can't get it back on. Nothing at all happens when we plug it in. The power won't even come on.
  • choungtran Apr 30, 2008
    thx it turn out it was the cord with the big thing on it that was unplug
  • leaB Jun 06, 2008
    haven't used my wii in a week, went to switch it on and nothing!! no light, no power, nothing. HELP. 4 kids going mad
  • AndyBeronia Jan 13, 2009
    just bought my we for my son, he was creating "characters" and then, it just turned off, it will NOT turn back on...it's dead!
  • mandamandy Jan 13, 2009
    My son was playing with the wii game ,I was not there to see what game. He said Mario that we have and the game turned off and went dead and I cannot get it back on.
  • AMC9106 Jan 13, 2009
    I bought a charging station for my Wii and the two remotes. It charged everything fine and up until yesterday, the lights shut off and I can't get it back on. I have it plugged into a surge protector. We did not have any type of storm. I rechecked all the plugs and it still won't turn on. I got the console for Christmas so it is not even a month old. What do I do?
  • crystalga238 Feb 14, 2009
    i was playing and it turned off i tried leavin it alone for 1 hour... can anyone help
The light on our Wii would not turn ON, and would not power up. No red, no yellow, nothing.
To fix, we unplug the Wii console. We turn the WIi console so that the back-side fan area is pointing towards the ceiling and then vacuum the fan area. Then we place it back into the Wii stand, plug it in, and the red light comes on. It powers up and works perfectly again. Obviously this won't solve everyone's issues (i.e. electronic component failures), but it has worked several times for us. Definitely worth a shot before shipping your unit off for repair.
I think the fan gets clogged and WIi protects itself from overheating, but do not really know why this works... but it does!
Posted on Feb 15, 2009
  • 35 Answers
Sooo... um my guess is: are the plugs in the right spot? like the video and audio, maybe the quebistonary motor isnt working. i mean the motor.
Posted on Apr 28, 2008
Cannon penncraft cannon work
Get two short extension cords and cut the FEMALE end off each one. Strip back the insulation on that end. Connect the two green wires to each other, and connect the two white wires to each other.
Connect one black wire to a light switch, and connect the other black wire to a 20W appliance-type incandescent light bulb. Also run one short black wire (from a cut-off end) from the second terminal on the light bulb to the second terminal on the switch, like so:
plug -- black -- switch -- black -- bulb -- black -- plug
plug -- white ----------------------------------- white -- plug
plug -- green ---------------------------------- green -- plug
Turn the switch to the OFF position.
Start the generator. Plug one plug from your new rig into an outlet on the generator. Plug the other plug from your new rig into a wall outlet supplying 120V. With the generator running, turn the switch to the ON position.
The bulb should flash for a short while, then become steady. When it's steady, that side of the generator is flashed. Repeat for the other side of the generator if it makes 240V.
Jul 12, 2014 | Electrical Supplies
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
No power to my wii. outlet is good.
Try the Wii in another working outlet just to see if it turns on. If it doesn't then try another AC Adapter in the Wii. If it still doesn't turn on with a new AC Adapter then that means the mainboad is bad inside of the Wii. If the Wii turns on then that means your old AC Adapter is bad.
Jun 04, 2010 | Nintendo Wii Console
Wii won't turn on
Hello :
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
While you're waiting, check the AC Adapter for the following:
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power
good luck .
rate please !
Mar 23, 2010 | Nintendo Wii Console
Wii has been working fine. Now the power light is not on and everything is plugged in correctly and outlet works. Cannot get power light to turn on.
If your Wii has been damaged or got hit by something, then that could be the problem. I would go to the store and ask them what the problem is. They should help you with that problem. Hope that helps.
Mar 22, 2010 | Nintendo Wii Console
Why wont the wii power on
please check all power and connection cables to make sure that everything is connected correctly. If that does not work then please change outlets and see if it works better. If that does not work then you have a hardware defect which should be covered under warranty with the manufacturer so you should contact them for futher assistance.
Mar 04, 2010 | Nintendo Wii Console
Won't work after power out
Just had the same issue after a brief power outage. Following the advice on this board, I simply unhooked the power cord to both the Wii and the outlet, waited a good 10 mins and hooked the cord back up - first to the outlet then to the Wii. Presto! Power light is back on.
Jun 19, 2009 | Nintendo Wii Console
Wii won't power up
Leave the wii power brick unplugged from the wall socket for 15 min then try to plug it back in. This worked for me.
Jun 11, 2009 | Nintendo Wii Console
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
521 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
