Question about Westinghouse Refrigerators
I have a Westinghouse Freestyle Fridge about 6 years old. I want to know how to remove the seal from the doors. Could you please advise me? Colin
Sea Breeze
  • 4655 Answers
SOURCE: Westinghouse RP423 Freestyle fridge cooling failure
I am going to assume you are in the UK. the voltage is higher than most household refrigerators here in the USA. Disconnect power to refrigerator and check continuity on two of the three terminals of the compressor at a time until you measure the resistance in the windings all the way around. The terminals should be marked R, S and C. (Run, Start and Common) you should get a reading with your multimeter all the way around. When you have done this and have the readings I want you to touch one end of your multimeter to the metal pipes or any clean metal outside the compressor and the other to one of the three terminals one at a time like you tested before. With your multimeter set up the same, see if you get a reading from metal housing to the three pins, or terminals c, r and s. You should get no reading. If you do, the compressor is a burn out and on the first test if you don't get a reading on the two at a time test between two post that is considered to be open or broken windings. The compressor does have an internal overload that may be open also. But if cool at time of test, and it shows up the compressor in bad. Let me know what you find...Thanks, Sea Breeze
Posted on Apr 24, 2009
  • 5 Answers
SOURCE: My larder fridge (only 2 years old) suddenly
It may not be defrosting, check that out.
Posted on Sep 11, 2009
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Posted on Oct 13, 2009
SOURCE: Westinghouse freestyle fridge. Fridge compartment
likely a malfunction somewhere in the defrost system, i.e., the defrost timer control, the defrost heater assembly, or the defrost bimetal thermostat
Posted on Mar 01, 2010
Testimonial: "Very helpful, thank you"
  • 51 Answers
SOURCE: im after a manual for
You can go visit onlinand Google.www.manual for westinghouse freestyle fridge RJ422T-R
Posted on Oct 24, 2010
The freezer door at the bottom of my Westinghouse French Door fridge won't shut properly on one side. It is 4 years old, it seals at the bottom but not the top.
Probably slipped off of track. Empty until light enough to completely remove drawer. Make sure guides are intact and reinstall properly.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Feb 20, 2017 | Westinghouse Refrigerators
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
Door seals rotting out on westinghouse freestyle 920 dishwasher
If the machine is kept idle for long time without use, these types of problem happens.
When not in use, apply talcum powder over the gasket. Moist the powder and apply as it will fall off . Leave the door slightly open by keeping some folded cloth or some other soft material and close the door.
Contact the service provider and protect the electronics by a water-resistant cover.
May 26, 2010 | Kenmore 15129 Built-in Dishwasher
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
I have a westinghouse freestyle fridge and it is leaking water seem to be coming from behind the tempreature adjusting knob. Do you have any suggestions. Thanks Michael model RJ452T-R
Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Nov 03, 2009 | Westinghouse Refrigerators
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
Westinghouse freestyle 920
was there damage to the door,when the door closes is it closing freely or is it hitting the cabinet on both sides it may need to be pulled out about 1/2 "
Dec 29, 2007 | Kenmore 15129 Built-in Dishwasher
Freezer Icing Up
Try contacting the hotline again and ask them if the freezer has a frost sensor on it. If it does, the sensor is not kicking the thermostat to allow for the unit to defrost.
Oct 21, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
27 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
