Question about Lands Phones
We have a panasonic PQJX2PSLO1Y system at our office. When the switch board rings.. how do i retrieve the call from another phone in the office
Centernet
  • 38 Answers
SOURCE: Incoming call indicator light
Yes!
The easiest way is to assign a DSS button for each person. When their phone is ringing, the DSS button will flash (on most systems - older systems don't do it and newer systems can be programmed not to).
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
rockitman187
  • 2559 Answers
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Posted on Feb 12, 2009
    consultel1
    • 860 Answers
    SOURCE: Incoming calls to office cause all phones to ring in classrooms
    Changing ringing on a Partner system is done on either ext 10 or 11.
    At one of those ext's press the feature key and "00"
    Next press the left hand intercom twice
    The display should say system programming
    Press the right hand intercom once. The display should say Centralized Programming.
    Enter in the extension number that you want to program.
    Press the line that you want to ring.
    A solid light on the line means immediate ringing
    A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
    A fast flashing light means no ringing.
    When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
    Press feature "00" to logout
    Hope that helps
    Posted on Feb 19, 2009
    consultel1
    • 860 Answers
    SOURCE: Norstar m7310 I would like to set more phones to ring
    To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
    At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
    The display should sat LINE ACCESS
    Press the show key (top right arrow) .
    The display should say LINE ASSIGNMENT.
    The display ask for a line number. press list
    The display should sat line 001: appear only press CHNG til it says appear &ring.
    press next key (lower right arrow)
    The display should say line 002: appear only
    Repeat same procedure as line 001 til all available lines are done
    press the release key when finished
    if the programming doesn't look like 1 described call me @1.410.984.4840
    Posted on Mar 25, 2009
    cnavarro
    • 2460 Answers
    SOURCE: Call forwarding
    The 50 command is for call forwarding of an individual phone, not the incoming calls. There are several conditions that have to be met to make forwarding work. First, you need your ICD group extension. It's generally 600, but we use 100 or 199 or 200 sometimes. The command is in the back of the Operations Manual (OM) and it is in the form of (assuming 600) *71416009+number#. *7140600 cancels.
    http://www.public.carl.airpost.net/TDA/200_TDA_OM_06-121.pdf
    Here's a copy of the manual, just in case you don't have one. Page 192 shows the sequence. You might also look at *710 command on the same page for setting forwarding. It is quicker than the 50 commands and sets the status of your FWD/DND button.
    Carl
    Posted on May 11, 2009
    Don't know the extension to check messages.
    I need to know what phone system you have. If it has a VM system and the model of that unit.
    I am going to make a hunch here that you have a KXTD unit (816 or 1232) and a VM system that goes with it. The system will know who you are by extension number when you hit a red lit Message lamp on the phone. If it is off, use Intercom 165. In most cases you will need the password otherwise you will need to reset them. I caution you that you should get a Panasonic tech into your office to handle this for you though.
    Sep 18, 2017 | Panasonic BTS Panasonic KX-T7433 Black...
    We have a Panasonic KX-T4030 in one of our offices. We're trying to figure out how to have it NOT ring unless a call is being put through. As of now, it rings everytime the reception phone rings. Is it...
    The 7030 is connected to something Panasonic. Guessing it's a TA-624 but it doesn't matter. You need to find a manual for the KSU. Ringing is usually programmed in SYSTEM programming from a phone connected to the first jack in the system.
    Carl
    Mar 25, 2011 | Panasonic KX-T7030 Corded Phone
    I bought a home with the Panasonic KX-t7731 phone system installed. We have a new phone number. I am unable to set up voicemail (although voicemail answers) and I am unable to retrieve my messages. Help!
    What's answering the calls, is it the Panasonic system or the central office? When you figure that out, and it's locally, then post back with the model number of your phone sytsem cabinet and whether you dial 107 or 115 ot get into voice mail, or the message is left in the central office.
    Carl
    Aug 31, 2010 | Panasonic KX-T7731 Corded Phone
    Ring to other phones other than the switch board
    When the system was installed, if you or your installer programmed it properly you set up ICD groups. Each extension that you want to ring goes into the members of the group and you can specify how the phones ring. It will also blink the buttons on incoming calls and you can pick up the call from anywhere by just pressing the button.
    The programming manual is pretty specific on how to set ICD groups up. Your 5 fing delay is fairly long, so other factors need to be considered regarding intercept and No Answer call forwarding.
    It's beyond the scope of a free forum to give specific programming help.
    Carl
    Oct 13, 2009 | Panasonic KX-T7633 Corded Phone
    Is it possible to divert my panasonic phone to my mobile? its make is pqjx2pslo1y
    You can subscribe to call forwarding from your telephone company. You can send your calls to any telephone number ... maybe/probably ... in the country and maybe beyond. It will depend on the limitation of (1) your pocket book and (2) what yout phone company allows.
    I hope this helps
    a
    Sep 25, 2009 | Panasonic Lands Phones
    I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP -PBX PHONE SYSTEM WITH PANASONIC PHONES KX-T7633 PHONES.WE HAVE NINE PHONES IN THE OFFICE AND I CAN ONLY GET 1 TO RING ON INCOMMING CALL HOW DO I GET ALL...
    In program no (620) enter all the extension nos which you want to ring in group 1. Then in program no (450) enter the floating no of group 1. You will get the floating no in program no (623).
    Mar 23, 2009 | Panasonic KX-T7633 Corded Phone
    Remote access, panasonic cordless phone and answering machine
    I phoned in from another phone and retrieved my messages. The problem was not with the answering machine but with the phone and calling card I had been using. Don't use a hotel switch board nor calling card, too many intermediate parties for the 2 digit code to work with.
    Aug 18, 2008 | Lands Phones
    Panasonic kx-tga2348
    have a nine year old panasonic phone trying to get the ringer turned on to ring
    May 20, 2008 | Panasonic KX-TG6502B Expandable Phone...
    Yes!
    Mar 20, 2008 | Panasonic KX-T7633 Corded Phone
    Ring tone
    Here is the instructions The full manual can be found here.
    http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7633
    Oct 29, 2007 | Panasonic KX-T7633 Corded Phone
    Lands Phones Logo
    218 people viewed this question
    Top Lands Phones Experts
    Marvin
    Marvin
    David Burbee
    David Burbee
    Are you a Lands Phone Expert? Answer questions, earn points and help others
