Question about Dishwashers
We have purchased a new home and it has a Westinghouse touch dry, SB915 installed. First use, water appreared on the floor at the front. Unable to to determined where leak coming from without pulling out unit. Can you recommend a suggestion or an authorized service technician in the Aberfoyle Park SA area (5159). Thankyou
Hi check the lineament of the dishwasher door if the dish washer is not level front to back and side to side it will be lop sided and the door seal may not be depressed enough and may leek from the bottom part of the door seal too ways of checking this is to run a level inside the unit side walls and a small level for side to side leveling the other is to just close the door and at the same time checking the inner chrome part of the door with the inner side walls as they should not clash nor be closer to one side than the other i hope this helps as it is hard to explain
Posted on Mar 29, 2009
I have just bought a second hand dishwasher, touch dry sb915. The water is not getting hot and they are wet at the end of cycle. I have read previous q&answers, one said to tilt and there will be
Hello Cathy I have fixed many appliances by using the
RepairClinic web site. Normally the hot water is boosted to 180 F
to sanitize the dishes. The incoming hot water supply could be around 120 F. Perhaps the heating element needs replacing. Have you looked at the Westinghouse web site ?
Ken
Jan 03, 2015 | Dishwashers
Our Westinghouse Sb915 d/washer does a whole wash but the tablet is not all dispensed and dishes not clean. Tried three times now with new tablet each time and still same result. Never had this...
Do you live in an area with hard water? Hard water can this problem. Here's a map. To determine water hardness. http://www.citriclean.net/why-citriclean/
Aug 25, 2013 | Dishwashers
Dishwasher Westinghouse SB915 fills with water for wash cycle but does not wash.
Contact Westinghouse directly to request the wiring diagram.
May 30, 2017 | Dishwashers
My dishes come out clean but wet. They used to always come out dry. Do I need a service or replacement part? I have a Westinghouse touchdry SB915.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2011 | Westinghouse Dishwashers
Hi, we haven't got a manual for our Westinghouse touch dry SB915 dishwasher and the lock has been activated. How do you unlock it?
press hold in for few seconds if not get unlocked you have to get new on and of switch due to this dishwasher switch burns out its popular with this dishwashers power switch burns out
Dec 27, 2010 | Dishwashers
Runs through entire cycle fine but water is cold
you need replaced the control board its very popular with this dishwashers cost around $220 as i have replaced mine
Apr 07, 2010 | Fisher DD603FCSS Dishwasher
Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Dec 13, 2009 | Westinghouse Dishwashers
Westinghouse SB915 wont heat up water
found the 2 large lugs mounted on the circuit board had been hot and had dry solder joint's removed solder cleaned with sand paper then re soldered and tested it now heats up .
Jul 26, 2009 | Westinghouse Dishwashers
Westinghouse sb915 will not heat element shows 25 ohms when tested.
Westinghouse SB907 had same problem, which I had thought might be the heating element. Fixed relay soldering on PCB where it was burnt/melted, now works! This probably applies to the Westinghouse SB925 also.
Jun 02, 2008 | Dishwashers
Dishwashers Logo
296 people viewed this question
Top Dishwashers Experts
