Question about Dryers
Can i download instruction manual for a white knight tumble dryer
  • 171 Answers
The best place i have found on the internet is APPLIANCEPARTSPROS.COM. you will need the model number and if it is not listed the ask you to call them and they will try to help.
Posted on Aug 06, 2010
5 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Posted on May 02, 2009
beltronic205
  • 1474 Answers
SOURCE: White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Posted on Oct 01, 2009
ftw1952
  • 10319 Answers
SOURCE: I am looking for the user manual for a White
Go to freemanuals.com They have assorted manuals there to download
Posted on Apr 04, 2010
Testimonial: "will take a look right now, thanks "
  • 494 Answers
SOURCE: WHITE KNIGHT TUMBLE DRYER NOT DRYING?
Here's a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
1) Obvious things first. If you have a propane gas dryer, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. Order a gas delivery.
2) Another obvious tip. Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum attachment and clean out lint. This applies to both gas and electric2_bing.gif dryers.
3) Most gas dryers have either a small access panel in the front or at the very least, a peep hole. Open the panel or pop out the plastic peep hole cover so you can view the igniter. Turn on the dryer and watch for orange glow at the burner. If it does not glow, it will not light the gas burner. You may have a broken igniter and will need to replace it or have a new one installed. If you do it yourself, be sure to unplug the dryer and do not touch the very fragile ceramic piece of the igniter. You can confirm it is broken by locating the broken piece below where it is attached or noting it is missing a piece of ceramic on the igniter.
4) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes2_bing.gif no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners2_bing.gif can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps.
Posted on May 23, 2010
Can anyone help me plz, i have a 37AW white knight dryer,my partner slammed the door too hard and the dryer hasn't worked since, has anyone got any ideas how to fix it, or tell me what to look for?
Probably broken the door switch which stops the drum when the door is opened. It may even just be the nylon strike pin that presses the switch.
White Knight 37AW Tumble Dryer Spares ' White Knight Spares
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw/catalogue.pl?path...ref...
White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 37 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Spring For Door Latch.
White Knight 37AW Tumble Dryer Spares - WhiteKnight-Spares, Parts ...
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw.../catalogue.pl?path... White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 36 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Door Window - Clear.
White Knight 37AW Tumble Dryer Parts ' Partmaster
https://www.partmaster.co.uk/tumble-dryer/37aw.../catalogue.pl?...whiteknight... White Knight Tumble Dryer parts - repair your White Knight Tumble Dryer with a ... White Knight 37AW Switch Strike ... White Knight 37AW Spring For Door Latch.
37aw white knight dryer door switch Google Search
Jun 06, 2018 | Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
video section
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
What is the load capacity for a 84 AW white knight tumble drier?
5Kg
White Knight 84AW White Tumble Dryer by White Knight Be the first to review this item
Currently unavailable.
We don't know when or if this item will be back in stock.
  • Construction: Freestanding
  • Control of Drying: Timer Control
  • Display of Remaining Time: No
  • Energy Consumption in kWh at 1400 RPM: 2.5
  • Energy Consumption in kWh at 800 rpm: unknown
  • Energy Efficiency: A
  • Energy Savings Trust Feature: Yes
  • Heating System: Electric (incl. Heat Pump)
  • Height in cm: 85
  • Maximum Loading Capacity in kg: 5
  • Start Delay Option: No
  • Type: Ventilation
  • Type of Loading: Front
  • Width in cm: 59.6
84 aw white knight tumble drier capacity Google Search
Feb 19, 2018 | Dryers
I have a white knight WK447 with 2 buttons on the front. Which one do you push in to dry quickly please?
here is a website to download information on your dryer, Good Luck Tim:
http://search-pdf-books.com/white-knight-wk447-tumble-dryer-pdf/
Jan 16, 2011 | Dryers
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Apr 19, 2010 | Dryers
I NEED A USER MANUAL FOR THE WHITE KNIGHT CONDENSER DRYER CL 767
Crosslee plc is an appliances company formed from the tumble dryer division of Philips. Its best known products are White Knight brand tumble dryers. The company is based in Halifax, West Yorkshire, England.
here is ther main webpage:
http://www.crosslee.co.uk/english/index.html
Try contacting them thru e-mail about getting manual most company's will give a copy/or post one on their website for free.
good luck
Aug 04, 2009 | Dryers
Just replaced the heating element
Apr 11, 2009 | Dryers
Dryers Logo
548 people viewed this question
Top Dryers Experts
Marvin
Marvin
