Question about Alpine MRV-F345 Car Audio Amplifier
Wiring door speakers
I just got this new amp and i was wanting to hook them up to my aftermarket door speakers. I have a 2004 Honda Accord EX. Thanks
    Genius:
  • 1,673 Answers
Just make sure that the speakers are the correct impedance and properly rated. If not, the amp can be damaged.
Jerry G.
Posted on May 01, 2008
2004 honda accord ex how to remove pasenger side front speaker
You must remove the door panel (apply gentle pressure around several points between panel and door, end removal of at least one screw in the inside door handle). Once the interior panel is removed, there are several screws holding the speaker in place. Remove these screws and the speaker (once disconnected from the wiring) will come out.
Jan 15, 2014 | Vehicle Parts & Accessories
Removal of door from honda accord ex
12mm wrench for bolts, 10mm on center stay(holds door open) and if its power you have to run the wiring in and out of the door. Not very complex
Nov 28, 2013 | 1996 Honda Accord
I have a 2004 Honda Vtec 2.0 Exec Auto. The radio has 8 speakers, 2 at the front, a speaker in each of the 4 doors and two at the rear. The two at the rear are not working. I have checked all the radio...
the quickest and easiest test is to disconnect one of the rear speakers and hook a good speaker to it and see if it plays, if it does then its bad speakers and not wiring, this is the best way and easy to do, hope this helps, good day.
Sep 03, 2011 | 2004 Honda Accord
I have a 1999 Honda Accord with a CD radio with no extenal speaker connection. I have a new XM radio and want to connect the radio to the speaker system. How do I find the place to acces the cars...
Hello! Pull the radio...There is a connector with the following speaker wire colors...
Front driver door + Red/Green
Front driver door - Brown/Black
Front pass. door +Blue/Green
Front pass. door -Gray/Black
Left rear+ Blue/Yellow
Left rear - Gray/White
Right rear + Red/Yellow
Right rear - Brown/White
If the vehicle is an EX the left and right Tweeter's are the same as the Front drivers/Passenger door speakers and merely connect to them...
Guru...saailer
Dec 25, 2010 | 1999 Honda Accord
Replace a door speaker in a 1997 honda accord sedan
It's pretty easy to do. First, get a pry tool from a parts store to aid in getting the door handle off. While you are there, get a pry tool to aid in getting the clips off from around the outside of the interior door panel. Take those items off, unscrew the door arm rest screws and you're golden. unscrew the existing speaker, match the size with a new one, hook up your wiring, test the speaker by turning on the power and playing the radio and once you confirm you have a working speaker, put it all back together.
Sep 21, 2010 | 1997 Honda Accord
Is it possible to connect an iPod to a 2004 Odyssey EX stereo?
Yes you can connect an ipod to both stereos ..but first you willl needc the wire that allows you to hook it up to the radio or get a radio tuner that you put to a radio station and then your ipod plays on it
Mar 22, 2010 | Buck Honda Odyssey 2004 Car Stereo/radio...
No sound dual xhd6420 92 accord lx
my brother has a 1993 Honda accord and had the same issue, we put it different speakers and it worked fine, don't know what the problem was but it worked
Feb 12, 2010 | Dual Electronics XHD-6420 CD Player
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
Rear speaker size in my 1993 Honda Accord
I HAVE A 93 ACCORD LX AND ACCORDING TO HONDA MINDS COME WITH 6.5" SPEAKERS FOR THE BACK AND TO GET 6X9 IN YOUR GOING TO EITHER GET THE SPACER THE COME WITH THE EX OR YOU OR GOING TO HAVE TO CUT AND THEY DONT RECOMMAND IT CAUSE YOUR TRUNK WONT STAY OPEN AND YOUR GOING TO HAVE TO BEND THE BAR UNDER THE TRUNK. HOPE YHIS WAS HELPFUL.
Dec 16, 2008 | 1993 Honda Accord
Alpine MRV-F345 Car Audio Amplifier Logo
54 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
