Hp Pavillion DV7-1245dx ram info. I am thinking of upgrading the laptop to 8gb of ram. but wondering when the specs say the max is 8gb of ram and up to 2gb of ram for the video card. ok, so if that is correct how do I upgrade the video card ram? do I just upgrade the computer ram and it is shared and I can reserve some just for the video card? or how would I utilize the 2gb of ram for video card? here are the specs listed below. would it be worth it to upgrade the ram? will the extra 4gb of ram really make a huge difference? just trying to convince myself to spend another 300$ on my laptop for gaming. thanks guys. Microprocessor AMD Turion X2 RM-72 Dual-Core Mobile Processor Microprocessor Cache 2.10 GHz Memory 4096MB Memory Max 8192MB Video Graphics ATI Radeon HD 3200 Graphics RS780M Video Memory Up to 1918MB Hard Drive 320GB (5400RPM)
  • 1 more comment
  • Robert Dressler Aug 06, 2010
    you do know i am talking about a laptop right? so yes you can share ram with the video card with computer ram.
  • Robert Dressler Aug 07, 2010
    can you upgrade the video card? I cannot find anywhere to buy. if you are not able to buy a replacement upgrade then why is my computer able to have 2gb of ram for video card? confused.....
    you even speaking English? I have Vista premium 64 bit. i don't want to up-grate, i want to upgrade. Come on guys. is there a removable video card in a hp pavilion dv7? I cannot find anything about this. Thanks.
    Novelist:
  • 87 Answers
Pfcdressler,
Doubling your amount of RAM will definitely make a noticealbe difference. It is by far the most cost-effective way to increase the usability of your computer.
Just remember that you will need to be running a 64-bit Operating System in order to utilize more than 4GB of RAM; with a 32-bit OS you'll just see 4 gigs no matter how much ram you install.
If you are already dropping this kind of money to speed up your computer I would also suggest going for a solid state hard drive.
Finally, looking at reviews for this HP laptop you may consider just biting the bullet and buying a new computer. For a $700 computer, $300 seems like a whole to put a temporary fix (no matter how much RAM you put into this computer, while it will be lightning fast loading things up, the cpu-intensive applications will still be limited).
Further, check out my tip on speeding up your computer here:
http://www.fixya.com/support/r5347471-speeding_up_computer_windows_xp
To reiterate - go for a RAM upgrade, but I would find some RAM at a more reasonable price, maybe only go for 6GB total and be sure to guy online at sites like tigerdirect.com or newegg.com
I hope this helps, good luck creating a high-performance gaming machine!
please rate my solution
Posted on Aug 07, 2010
    i would rate it, but where do you do that?
    Genius:
  • 1,354 Answers
Hi
your issue is you would like to UP-grate your RAM in this case
what type of your OS ,
first check your windows it's 32bit or 64bit
if your window is 64bit then only you can get 8 GB RAM support if you have 32bit then don't up-grate your RAM becoz it will just support up to 4 GB only
about your video memory if you have separate graphic card then it will not tek any memory from your RAM
you have to up-grate your graphic card only
  • hi
    in this case you have to find technician to remove your graphic card it's long process
    yes you can remove if *********** board has a bitten VGA port
  • 4,737 Answers
Well, your Laptop's video card is not integrated which means it's not sharing the memory with Ram. If you would like to upgrade the video memory, you need to purchase another video card with larger memory capacity and install it in place of the existing video card. Upgrading your ram will not effect the video memory. Suppose an integrated (onboard) video card memory is 512mb, and the ram is 4 gb then at least 512mb will be shared and will be reserved for Video card automatically.
Yes you are right when you say that your system has max 8gb of ram and max 2gb memory upgradable . But it's not integrated with the motherboard, the graphics card is installed as a dedicated hardware which's been installed on the available Video slot.
And, of course, if you upgrade the Ram to 8gb, your system performance will be improved, which means your video quality will also be improved virtually (will perform better as a whole), as you know, the whole system improves the speed after upgrading the ram even if you don't upgrade the cpu.
I hope this helps.
Good luck.
Thanks for using FixYa.
Posted on Aug 06, 2010
    Guru:
  • 825 Answers
For upgrading the video card ram you need to replace your video card with a new one with greater ram capacity, it is not possible to upgrade ram alone for video card...! computer ram will not be shared with video ram, they both run in a different path...computer ram is shared only with direct components of motherboard like on-board VGA,sound etc...! the 2 Gb ram for video is completely dedicated to video graphics, and hence it cannot be shared or used for other purposes...! Increasing the computer ram will increase the performance of computer and upgrading the video card will increase the performance of games and graphics on your computer...! if you need to play games, upgrade your video card thats enough... but upgrading your computer ram will never make a huge difference on system performance because 4 gb ram is more than enogh for best operation... if you upgrade to 8 gb around 4gb ram will stay idle without any function...
  • Manikandan Raj Aug 06, 2010
    dude... whether it is a laptop or desktop, motherboard works functions in a same manner...
    ram memory will be shared only with Onboard vga cards and not on standalone AGP cards...
    eventhough yours is a laptop, the AGP card would have been mounted on your board and definitely it will be manufactured on-board... you agree with that...???
    the same model laptop with similar configuration other than the graphics card would have sold at a lesser price comparedd to your laptop...do you agree or not...???
    do you think that the laptop with the graphics card and without the graphics card are manufactured seperately...???
    if you have any doubts you can definitely give a try on your own...
    before that jus have a look at these links...
    link1
    link2
    google out for much more....
Aspire 7735z 4952
Yes, the max. amount of RAM you can install is 4Gb
The RAM slots is located behind a panel on the bottom of the laptop. Check out this WEB site for the RAM specs.
http://www.cnet.com/laptops/acer-aspire-7735z-4357/4507-3121_7-33826792.html
May 07, 2013 | Acer Aspire Computers & Internet
Laptop currently has three 4GB RAM sticks, is it possible to use another 8GB stick to upgrade it to 20GB?
It should. But RAM slots have a maximum RAM per slot. Have you checked with manufacturer manual to see what the max ram per slot is? And the max ram per motherboard matters too. Your mobo will only support so much ram.
Dec 07, 2012 | MSI Gt70 0nc-051us
HP Pavilion dv7 ram upgrade, came with 4gb ram, supposedly is able to upgrade to 8gb, is this possible?
Yes. The specifications say the MAX memory is 8GB
You should go to Crucial.com and run their online tool for ram upgrades. It will tell you exactly how much and what type of memory to add.
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
I just got a 1 gb ram memory from you for my pavillion zv6000 laptop. I opened the back to install it and there is a ram in there already. I thought I was just adding memory. help
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
section 5.6 gives memory specs, earlier in the manual it only refers to one memory slot. You have to pull the existing one.
I always tell my customers what the max memory you can install, and what will have to be removed. Apparently someone else didn't.
You might want to download that pdf. It's the full maintenance manual on your machine.
Jan 08, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
What is the maximum Ram supported bu Intel 1.86
Your system has a maximum capacity of 2 GB of SDRAM - 266.0 MHz
Jan 05, 2010 | HP Pavilion dv1000 Notebook
256 MB DIMM#1(DDR333) UPGRADE TO 2GB RAM in compaq nx6110 pc notebook
You should be able to upgrade to 2 gig. Here are specs. Good Luck.
512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
  • RAM configuration features 2 x 256 MB
  • Nov 20, 2009 | HP Compaq nx6110 Notebook
    Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
    Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
    Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
    Etower 633id runs very slow. Only has 64MB of RAM.
    Normally upgrading bios does not require flashing the bios. But in order to find out the max amount you can upgrade too requires some info off the motherboard. You need to get the model number off the board to look up the info
    Dec 24, 2008 | E-Machines etower 633id PC Desktop
    What can I safely upgrade to for gaming
    0Hi there,
    The Pavillion dv4t comes with a choice of specs to meet your needs. As you haven't listed them I will list the Minimum that you will need to run the games, that way, you can check them against what you have and decide if you need to upgrade.
    I will list for Sims 3. Even with the basic dv4t you will not need to upgrade to play Sims 2.
    Sims 3
    Running Vista SP1
    CPU (processor speed) - 2.4 Ghz Pentium 4 or Athlon 2400+
    RAM (memory) - 2 GB
    Video Card (graphics) - 128 MB (Nvidia GeForce Go 6200, ATI Radeon Mobile 9600, or equivalent)
    Hard Drive (space for installation) - 6.5 GB and an extra 1.5 GB for custom content.
    These are the minimum specs for running on a laptop.
    Hope that helps
    Tim
    Dec 19, 2008 | HP Pavilion DV4T Notebook
    Ram capacity on HP Pavillion dv2120us
    nope....that 2 gig is true..and the reason it may be invisible is that it is not seated properly, or, it is mismatched..
    Oct 16, 2008 | HP Pavilion dv2120us Notebook
    Computers & Internet Logo
    73 people viewed this question
    Alun Cox
    David Payne
    David Payne
