I have owended the product for around 90 days and was happy with the system . then one day i powered up and you could hear the sub get power but screen went out and will not play a sound and doesnt let you have any options, i checked fuse and seems ok
    President:
  • 2,185 Answers
That is why electronic devices has at least one year warranty. I would suggest that since it is still covered by warranty, you avail that by asking having it repaired or asking for replacement. It is the smartest thing to do since doing further fixes might revoke the warranty.
Posted on Aug 06, 2010
I have installed an brand new bizhub c 364 machine, now it gives me security lines either blue or red , can anyone help me in solving the problem ,thankyou
Install was done incorrectly,
CAUSE: Initial settings did not take when programmed.
SOLUTION: Time and date, telephone and ADF serial numbers need to be reentered:
1. Sub-power ON g Utility/Counter g Machine Admin settings g System settings g Date and time setting g (Enter year/month/day/time) g OK g Exit g Power OFF sub-power switch.
2. Enter Service Mode g System settings g Setup date input g (Enter year/month/day) g OK.
CAUTION: DO NOT POWER OFF. Leave machine in Service Mode.
3. In the Service Mode g System settings g Telephone setting g (Enter 16-digit number) g OK. Repeat for the fax number. Set to all 9s if there is no fax number.
4. In the Service Mode g System settings g M/C serial number setting g touch ADF g (Enter ADF serial number) g OK g Power OFF sub-switch.
5. Power ON sub-switch and run copies with no security lines.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 27, 2015 | Konica Minolta Bizhub C364 Color Copier /...
How many days can i leave my car without starting the engine?
It depends on the state of your battery, Your Blazer uses around 1mA of power for the computer and radio memory in 12 hrs. So a good battery should hold enough charge for 60-90 days.
Jun 10, 2014 | 2000 Chevrolet Blazer
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
The sub from my kef kht 2005.3 system is making a consistent electrical buzzing noise after an hour or so from being switched on. I only bought the system 5 days ago so taking it back is not too much of a...
I'm not too familiar with this system one thing you could try:-If the sub has separate mains power try disconnecting it from the main Amp. If it still buzzes the problem is the built in bass amp if it stops the problem is the main amp.
Jan 24, 2018 | Audio Players & Recorders
My power supply of Portable HP 6830s (19 v,4.74 A, 90 W) make recurcive sound (like a bip) and has no out put. How to open the box of this power supply?
Test by video examples:
These are the most common issues for laptops.
Good luck and have a great day
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Jul 16, 2010 | HP 90-Watt Power Supply
Is this a good product Siemens Super-Power LOTUS 13SP Digital BTE
Blueboy792,
If you havent gotten an answer since posting this question, let me just say that I have fit many Siemens Products over the years with great success. Their instruments are reliable and the company stands behind the product.
The hearing instrument you mentioned may or may not be the product for you depending on your hearing loss and your day to day hearing needs. You and your dispenser must determine this.
Hearing aids are generally adjustable and if you are not having the success you expected you must return to your dispenser for an adjustments.
I hope this info will benefit you. If you have specific problems with your fit please let us try to be of service. Thanks for contacting FixYa.com
Jul 18, 2009 | Select Products Siemens Super-power Lotus...
PS-212 Suddenly stopped working
I HAVE 4 PS212 AND FROM WHAT YOU ARE DISCRIBING SOUNDS SIMILIAR TO WHAT HAPPENED TO ME. PLAYING THE SUB AT FULL VOLUME AND CLIPPING OCCURED NOT KNOWING THAT THE FAINT SMELL WAS THE VOICE COIL BURNING AND CONTINUING TO PLAY UNTIL KNOW SOUND LESSON LEARNED BUY A BIGGER SUB SYSTEM OR REPLACE YOUR SUB WOOFER.
IN MY OPPINION THIS IS A VERY GOOD PRODUCT WHICH I HAVE BEEN ABUSEING FOR MONTHS . SO QUIT WHINEING AND PAY YOUR DUES.
May 30, 2009 | Infinity PS212 Subwoofer
Codes for chorus mmds (EUROVOX)
These are only for boxes that work with Chorus digita MMDS not cable
hit menu
go to system information
hit ok
type 1969
go to navigation
bring up provider
if you are with chorus then
the codes are: PROVIDER ID 5E 01
KEY NUMBER 00
key data: CE 19 23 87 80 61 74 90
KEY NUMBER 01
key data: 62 FA 09 F3 CE 05 F4 79
make sure your provider name at the top is reading CHORUS if not go to the provider id and right arrow until 5E 01 appears and when you have changed the codes store and exit you should be laughing!!!
best of luck HAPPY CHRISTMAS!
chorus
00:CE 19 2E 87 80 61 74 90
01:62 FA D9 F3 CE 05 FA 79
Dec 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
23 people viewed this question
 Grubhead
Grubhead
