Question about Taylor 632-27 Ice Cream Maker
Aloha, we purchased an existing frozen yogurt shop - incl. four (4) Taylor #794's - we believe they are approx. 10 years old - one of the machines (all are water cooled) is spilling out a brownish/ yellowish liquid from the back - and under the machine - what could this be ? What should we do ?.
  • Paul B Aug 06, 2010
    Aloha, we purchased an existing frozen yogurt shop - incl. four (4) Taylor #794's - we believe they are approx. 10 years old - one of the machines (all are water cooled) was leaking where the water in/out connects to the condenser coils - a significant amount of the cooling liquid for the compressor motor (brownish/ yellowish liquid) was lost as well... IF THE COILS ARE DAMAGED, CAN THEY BE REPAIRED - OR JUST REPLACE ? HOW DO WE REPLACE THE COOLING LIQUID FOR THE COMPRESSOR MOTOR ?
  • 2,272 Answers
Check the Water enter dump valve for the ice maker. It is leaking. It will not shut off & will cause this problem.The yellow/brownish color may be due to rusted parts in the unit.and water leaking is passing from this rusted part so this color of water is seen. Check out.thanks.
Posted on Aug 06, 2010
    Aloha, it seems the Taylor #794 (water cooled) was leaking where the water in/out connects to the condenser coils - a significant amount of the cooling liquid for the compressor motor (brownish/ yellowish liquid) may have been lost as well ??... IF THE COILS ARE DAMAGED, CAN THEY BE REPAIRED - OR JUST REPLACE ? HOW DO WE REPLACE THE COOLING LIQUID FOR THE COMPRESSOR MOTOR ?
    Guru:
  • 825 Answers
This is the cooling liquid for the compressor motor... It should not spill out... it says that the body is damaged...you need to refill the liquid again after fixing the issue with compressor body...
  • 2 more comments
    mahalo (thanks)... I just spoke to my son
    aloha, how can we fix the compressor coils ? how do we replace the cooling liquid for the motor ?
  • Manikandan Raj Aug 07, 2010
    yes definitely the compressor cooling oil can be refilled... Compressor motor cannot be repaired at your place, it needs to be shifted to the repair shop ...
    fix the leakage with compressor first and refill the cooling oil...
What is process to winterize a Taylor ice cream machine?
To winterize a Taylor 794, or almost any water-cooled Taylor machine, we need to get all of the water out of it. Follow the steps outlined here.
1. Remove the supply water hose from the water source.
2. Remove the rear panel of the machine.
3. Locate the water valves. Pictured below.
4. Have one person open 1 water valve. (You can scissor two screw drivers to take pressure off of the spring.)
5. Blow out all of the water with an air compressor until only air comes out of the drain hose.
Repeat step 4 and 5 for the other side.
046686 Water Regulating Valve 3 8
Sep 15, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
Product comes out frozen after all night on standby in a 754 taylor
The same thing happened to my Taylor 8756 and it was the thermistor probe. The probe is a thin copper tube that is near the freeze cylinder. It cost me about $20 for the part and $200 for the labor to have a technician put it in. Hope this helps and good luck.
Apr 18, 2014 | Taylor 2001 754 Air Cooled Soft Serve...
I have a Taylor 794 soft serve machine. The left side is too soft.
Viscosity adjustments should not have to be made frequently on these machines. If you change products a lot, such as flavors of yogurt, minor adjustments may be required. If your machine uses 3 phase electricity and it machine has been moved or any electrical work performed you may want to check the beater rotation, the beater should rotate clockwise inside the barrel viewing from the front, if you look at the gear box from the back, the pulley should be turning clockwise as well. Otherwise, there is a fine tuning potentiometer on the control, you must remove the front cover to see it. Clockwise is colder/thicker. I recommend small adjustments. It is best to read the amp draw on the motor to see what type of amps it is drawing. If your mix is soft and your motor is drawing 4 amps, you may have another type of problem such as a bad motor. The board and control can also fail giving these problems. There are many things to check in addition to these. Hope this will help you get started.
Apr 05, 2013 | Taylor Ice Cream Makers
Where can I find a repair man for Taylor Frozen yogurt machine? I live in Los Angeles, CA zip code 90024.
Call toll free number 1-800-665-1125 or www.dslinc.com and they will tell you who you can get in your area. The name of the company who services Taylor is DSL
Apr 09, 2010 | Taylor 632-27 Ice Cream Maker
Ice Cream Makers Logo
122 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
