Question about Whirlpool GBD307PDS Electric Double Oven
Display problem The display temperature has almost faded completely (hard to read) and the time is fading as well. Is this the circuit board. If so how do you replace it? sb
  • Anonymous Nov 20, 2008
    My board started to fade out and now board is completely dead - When i open oven the lights turn on.
  • 76 Answers
You can replace the display, however you have to take the face apart
Posted on Jan 01, 2009
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Display light board faded
Four years ago I had this problem (display goes dim, then goes out altogether) and fixed it per this post:
The circuit board for the display/touch panel is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.) You must use a high-temperature capacitor (105 degrees C, I think) or the problem will recur.
If your oven isn't put together the way mine is, this solution won't work - and I'm sorry to have taken your time.
Sep 16, 2013 | Jenn-Air W30400P Stainless Steel Electric...
My clock display is faded, oven works, no temp readings
the e o c ( the clock) is at fault . and the diag is correct . most parts today only cary 3o days .. hope the hepled . mm
Jul 13, 2010 | Whirlpool RBD305PD Electric Double Oven
Clock fades
Sorry the only way to repair is to replace the control board
Mar 28, 2009 | Frigidaire 27" Built-In Single Electric...
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
LCD display is blank , won't light up at all?
I had the same problem, mine faded out over time until I couldn't read it anymore. I had to have the circuit board replaced. The technician said that over time voltage surges can burn them out. It used to be frequent that I'd come home and all the clocks needed to be reset, so I know my area does have power problems.
The board comes out rather simply, I'd do it myself if if ever happened again.
Feb 10, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Jun 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Error code f cthermador sc301t
THE FADING DISPLAY IS A VERY COMMON ISSUE WITH TERM, BOSCH, AND JENN-AIR JUST REPLACING THE DISPLAY BOARD OR EOC DOESNOT SOLVE THE ISSUE DUE TO INCOMPATIBLE SOFTWARE YOU WILL ALSO HAVE TO CHANGE THE MAIN PWR RELAY BOARD
May 29, 2008 | Ovens
LED Display fading
As noted in solutions to other Jenn Air ovens, this is often solved by replacing the capacitor labeled C3 on the circuit board that contains the display. Oven heat apparently causes it to fail over time. This is a solder connection to the circuit board. Not hard if you have any experience with this kind of soldering it is straightforward.
Seven phillips sheet metal screws to remove panel assembly, plus two electrical connectors. One ribbon connector from touch panel to board, then four 1/4 hex sheetmetal screws to remove circuit board from touch panel and metal frame. Then soldering iron.
It did work on a 40300 dual unit, which is same as this model except for cosmetics.
Capacitor is 35 volt 68 microfarad. Radio shack has 100 microfarad, which one report says works. Radio shack doesn't have a 68, but they do have 22 and 47 which mounted in parallel give 69, which is within tolerance. That's what I used. The capacitors cost $1.29, less than 1% of the cost of a new circuit board.
Jan 15, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Whirlpool GBD307PDS Electric Double Oven Logo
232 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
