Question about HP Officejet 4315 All-in-One Printer
How do I reset my HP Office Jet 4315 All-In-One Printer
  • 25 Answers
SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Posted on Jul 08, 2008
SOURCE: Need software to install HP OfficeJet T45 printer to my Vista PC
I had the same problem, but was able to use my printer by adding HP OfficeJet V40 instead from the dropdown list. I didn't need to bring in a driver. Try it...it worked for me.
Posted on Apr 06, 2009
  • 144 Answers
SOURCE: Hp office jet 4215xi how to check ink level
HI
you may get the ink levels in several ways,
1) printing a test page.
2)if you got HP solution Center with the software cd of the printer ans it is installed in the computer,you can easily check the ink levels there.
3)sometimes ink levels option is available in the priner drivers in the printers and faxes in the control panel.
4)right clik the printer icon and then goto properties and then you will find tabs to check the ink levels,it might be in the service this device under the maintenance tab.
Feel free to contact me if there's any query.
Posted on Aug 03, 2009
moderator
  • 6 Answers
SOURCE: hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
Posted on Aug 12, 2009
  • 64 Answers
SOURCE: How to downkload hp office jet 4255 driver free
http://www.siliconguide.com/drivers/device/815/
There you can find your drivers.
Posted on Dec 10, 2009
Hp officejet 4315 series carriage jam, makes a loud clicking noise then jams fases light. virginiarortega@yahoo.com
A lot of times this is caused by something that has fallen into the printer - I just pulled a necklace out of one - when the cartridges are not at the far left or right pull the plug on the printer and move the carriage until it stops and look for an obstruction there
Jan 15, 2015 | HP OfficeJet Office Equipment & Supplies
I have a cartridge error on my HP Office Jet 4315 All in One printer. It tells me to look at the manual under troubleshooting. I don't have the manual anymore. Please tell me what I can do. Both cartridges...
Make sure you pulled the tape off the cartridge before you installed it, The tape covers the gold contacts that interface with the printer. also make sure they are snapped into place, and not just laying in there.
Oct 21, 2010 | HP Officejet 4315 All-in-One Printer
Printer going offline
unplug the printer's usb cable from computer then re-insert, leave printer switched on during process
Jan 28, 2010 | HP OfficeJet 4315 All-In-One InkJet...
Printer does not print in color
I have the 4315, so I am not sure if the answer is exactly the same. But there is a setting, for only printing in black ink and you need to disable it. Here is how to get to that setting: Go to
"File" "Print" "Properties" "color" UNCLICK "Greyscale" and unclick "Black cartridge only."
Jan 10, 2009 | HP Officejet 4315 All-in-One Printer
I dont have a cd to install
You can download the manual and other references here:
Retrevo HP 4315 manual +
Oct 19, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Hp Office Jet 4315 cancell a fax number?
go to the fax number, then try pressing the X button. Other wise if u are ready to loose all numbers, just reset the machine
Jan 08, 2008 | HP Officejet 4215 All-in-One Color Photo...
Hp office jet 4315
I have a HP Officejet 4315 All-in-One Printer
Won't print on paper. Possible cause or reason?
Thanks
reidcm@gru.net
Oct 12, 2007 | Compaq Inkjet IJ650 Printer
290 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
