My display is brake..what i do..?how to repair it,give me a video ..
  • 146 Answers
You have to buy a new monitor
Posted on Aug 06, 2010
Procedure for replacing rear rotors with disc brakes and abs on ford ranger 2010
I will try to give you a heads up on this job. The hard part is the emergency brakes hidden inside the rear rotors. You need to get slack from the self adjusters on the brake cable where the cable spools up under the dash on the emergency brake activator. Once you get a little slack, then you can shove the emergency brake levers to their neutral position. This will create slack inside the emergency brake drum and allow you to remove the rear rotor like you normally would for a front rotor. Otherwise the emergency brakes will create problems for removing the rotors.
If you have only worked on front rotors, the rear set is more difficult due to the emergency brakes. Get high quality replacement linings for the emergency shoes. Get new pins and mounting springs to secure the linings to the housing.
You may find some good Youtube videos for this repair. Or you may be better off to do the fronts yourself and take it in for the rear set. Realize there are more parts to buy for the rear since there are 2 sets of brakes back there. I do not like this system because it is not durable and the drum portion rusts to the point of uselessness. If you find a company to give a lifetime warranty for this repair you would be ahead.
May 07, 2018 | Ford Cars & Trucks
The display/control panel on my kitchenaid oven model KESC308LSSO is functional but does not light up. What part would I need to fix this? + looking for video of repair
I assume the display is hard to see but otherwise the unit function correctly? I'm going to gear my answer to this issue. If everything on unit functions but just can't see clock and temp. settings, you have a bad display. That's gonna be part #2. I'm not how to upload video but go to youtube and type in Kitchenaid slide in electric control replacement. The top video should give you a good idea on how to change display board out. Good Luck
Sep 18, 2017 | KitchenAid Microwave Ovens
Why does " service brake booster" light always on??
SERVICE BRAKE BOOSTER
Refer to Brake Warning System Description and Operation in Hydraulic Brakes
The SERVICE BRAKE BOOSTER message will be displayed when the supplemental brake assist signal circuit is toggled at 1.0 Hz with a 50 percent duty cycle. This message is also displayed if the instrument panel cluster (IPC) does not see an alive and well signal at key on. When this message is displayed it indicates a problem with the SBA and should be serviced or replaced.
How do the power brakes work ? Good .?
Service Brake Booster Message Displayed
Step
Action
Yes
No
Schematic Reference: Brake Warning System Schematics
Did you review the Brake Warning System Description and Operation and the Brake Assist System Description and Operation and perform the necessary inspections?
YES - Go to Step 2
NO - Go to Symptoms - Hydraulic Brakes
Start the vehicle.
Is the REDUCED BRAKE POWER message displayed for 1 minute before the SERVICE BRAKE BOOSTER message is displayed?
YES - Go to Step 3
NO - Go to Step 4
Perform the Brake Assist System Diagnosis
Did you find and correct the condition?
YES - Go to Step 12
NO - Go to Step 11
Disconnect the Supplemental Brake Assist connector.
Test the ignition 1 circuit for an open or a short to ground.
Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 12
NO - Go to Step 5
5
Test both ground circuits for opens.
YES - Go to Step 12
NO - Go to Step 6
6
Test the engine on signal circuit for an open or a short to ground.
YES - Go to Step 12
NO - Go to Step 7
7
Test the vehicle speed signal circuit for an open.
Did you find and correct the condittion?
YES - Go to Step 12
NO - Go to Step 8
8
Test the supplemental brake assist signal circuit for an open or a short to voltage.
YES - Go to Step 12
NO - Go to Step 9
9
Connect the supplement brake assist connector.
Disconnect the instrument panel cluster connector.
Connect a DMM from battery positive voltage to the supplemental brake assist signal circuit.
Turn the ignition to the RUN position while observing the DMM.
Did the DMM flash battery voltage?
YES - Go to Step 11
NO - Go to Step 10
10
Replace the Supplemental Brake Assist pump motor assembly Refer to Power Brake Booster Auxiliary Pump Replacement .
Did you complete the replacement?
YES - Go to Step 12
11
Replace the instrument panel cluster. Refer to Instrument Cluster Replacement in Instrument Panel, Gages and Console.
YES - Go to Step 12
12
Start the engine.
Does the Service Brake Booster message stay on?
Go to Step 2
System OK
Dec 25, 2016 | Cars & Trucks
Sony N50 pop up flash has a broken cable . It pops up ok but doesn't flash
My advice is to have it serviced professionally
  1. Henry's - Sony Digital Cameras - Canada's Greatest Camera Store‎
    Adwww.henrys.com/Sony-Cameras/Digital-Cameras This ad is based on your current search terms. Visit Google's Why This Ad page to learn more or opt out. Find The Best Discounts On Sony Digital Cameras At Henry's Canada - Shop Today! Droneopraphy Headquarters · Free Shipping Eligibility · Capture Your Memories
.spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
g-img{display:block}._WCg{display:block;border:0;position:relative} Search Results
SONY Camera Repair (Digital and Video) ' Authorized Repair Center ...
www.precisioncamera.com/sony-camera-repair.html
  1. Cached
  2. Similar
SONY digital cameras and video cameras can be repaired economically.
Sony eSupport - Electronics - Service & Repair
https://esupport.sony.com/CA/p/service.pl
  1. Cached
  2. Similar
Sony eSupport - Service & Repair. ... Headphones · Walkman Digital Music Players · Wireless Speakers · High-Resolution Audio · View All ... Video Cameras>.
Send in Repair - Sony
https://pro.sony.com > Home > Support
  1. Cached
  2. Similar
Click here for Sony Security Products Repair and Contact Information ... Arm Assembly; Brake Assembly; Digital Hour Timer; Upper Drum Assembly; Slip Ring ...
Sony Camera Repair - iFixit
https://www.ifixit.com/Device/Sony_Camera
  1. Cached
  2. Similar
Repair guides for a large selection of Sony digital and film cameras.Sony Camera troubleshooting, repair, and service manuals.
However, here are some DIY solutions
Sony Digital Cameras Google Search
Oct 30, 2016 | Sony Cameras
Front disc brake
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.Replace Scooter Front Brakes Adjust Rear Brake How To
How to replace scooter disc brake pads from RAC handbook series
Motorcycle Repair How to Replace the Brake Fluid and Bleed the Brakes on...
How to do front brake fluid flush Sum4Seb Motorcycle Video Motorcycle Repair Removing Installing Motorcyce Front Brake Disc on 2009...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 05, 2014 | Bajaj Motorcycles
Sound works but there is no display on the monitor. it worked for the first few days then now cant see nothing. Does the park brake wire have to be hooked up in order to show the display cause i know it...
  • Yes it does. The emergency brake wire is a safety feature. If you don't have it hooked up it won't even display anything. If you do have it hooked up then you have to have the emergency brake engaged to be able to view DVD'S. The manufacturer does this so people can't just unhook the brake wire and watch DVD'S while driving
Regards, Tony
May 20, 2011 | Pyle PLD61MU Car Video Player
My sony handycam DCR-HC38 do not plays the video in a right way , when video is played boxes and lines appear on the screen and no sound however a part of display is clear but not all the display.. i cant...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 01, 2011 | Sony DCR-HC38 Mini DV Digital Camcorder
Brake
if it was me i would give these website a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair Manual for your car wish you the best of luck Michigan Man
Jan 02, 2010 | 2004 Mercedes-Benz Mercedes Benz E Class
Warning on display
Check every item in your brake system.
a) Brake master - Check the brake fluid level. Also
find out if the brake disc at the wheel still hold
when the brake pedal is pushed. If not, brake
master needs repair kit .
b) Brake lines - For leaks .
c) Brake pad - for wear.
Send in e-mail comments, so we can help you further.
Oct 05, 2009 | 2004 Volkswagen Touareg
Computers & Internet Logo
12 people viewed this question
Alun Cox
David Payne
David Payne
