Question about Ovens
The Microwave equipment does not heat any thing when placed on the turntable. The turntable rotates, all the functions appears to be in place , but food does not get heated / cooked Model CE 945G ( 00027ZBK800451V)
  • 106 Answers
First check the HT fuse enlosed in a black or gray case or the micro switches at the door is faulty, if ok then the magnetron is dead and need replacement.
Posted on Aug 06, 2010
Do you take the turn table out when using both the microwave and the oven (combie)
No; if you're using the microwave you need to leave the turntable in to ensure the food heats evenly.
If you use just the oven or grill you can still leave the turntable in; there's no need to remove it. But you could remove it if you wanted.
Jul 25, 2011 | Ovens
I have a Sharp 980 A microwave which has been working perfectly for the last few years. Now we've recently moved to another place and when we tried it a week back, there was arcing, without any metal...
It was probably some damage during the transport. A microwave is an extremely dangerous appliance. Mu sincere suggestion is that you take it to a qualified repairman, have it repaired and ask for a certificate to verify that there is no radiation leaks anywhere.
Apr 02, 2011 | Ovens
Model KEMS308sss microwave not heating - light comes on, turntable works but no heating. Unit is 4 months old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 13, 2010 | KitchenAid Architect II KEMS308SSS...
GE JTP86 30" double wall oven: microwave will not heat and turntable does not rotate. Internal light works and electronic display functioning properly. 20 amp fuse is OK. What is likely cause?
This confirms that either the thermostat or magnetron tube is shot.The tube could be more than an old microwave is worth.
The cost of the magnetron would be around $125 and the thermostat is around $25.
Here is a good repair service if you choose that route!
To schedule service or for customer service issues please call 1-800-905-9505.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 20, 2010 | GE JTP86 Electric Double Oven
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
GE Microwave Model JKP85 Plate does not rotate
Usually this is a bad turntable drive motor in the floor of the microwave but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
TheRepairGuru ----- www.repairclinic.com
Click here For: GE-Microwave-Parts
Jan 26, 2009 | GE JKP85 Electric Double Oven
Turntable not turning
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Sep 11, 2007 | GE JTP85 Electric Double Oven
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
Ovens Logo
100 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
