Question about LG Computers & Internet
I am unable to adjust the screen to fit the monitor. The screen is bigger than the monitor and I cannot reduce the size using the menu buttons on the monitor. Is there anyway to use those options through the computer instead of on the monitor?
  • LG Master
  • 12,061 Answers
Yes right click on the desktop and click properties, when the window comes up, go to settings, and set to say 800x600, and click OK, this may sort you out.
Also ensure you have the graphics manager installed too.
Posted on Aug 06, 2010
I NEED MAKE MY SCREEN WIDEN TO FIT THE MOTINTER
depending on which you have some monitors have adjustment buttons on the front panel or just under the front panel
if so should be a menu button with possibly 3 other buttons one to move the creen inside the monitor others to expand and reduce the size click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Nov 06, 2011 | Computers & Internet
Got moniter working but screen is too wide for monitor i have to usw cross arrows to read the whole page
Each monitor has settings buttons on the front or side of the monitor to set the screen size, brightness, etc. Look for a button or wheel and find the menu, then go find the screen sizing, but verticle and horizontal and move it so it fits the monitor screen.
Pushing buttons on the monitor will not cause any damage, so try then all until you find the menu button and then you will need to find the button or wheel that moves you from selection to selection. Generally, pushing the menu button will select the highlighted menu item so you can adjust the settings.
I hope this was helpful.
Brian
Dec 24, 2010 | Computers & Internet
When using firefox the content is bigger than the monitor screen. how do i adjust the content horizontally to fit the screen?
Did you try simply holding the Ctrl key and pressing the minus (-) sign? That will zoom the content to a smaller size.
Sep 08, 2010 | E-Machines E15T3 15 in. Flat Panel LCD...
Dynex 19 inch tv used as pc monitor; the pc display is bigger that the width of the viewable screen which cuts off about 1/4 inch on each side making it difficult on some things to shut down since the...
\http://www.retrevo.com/support/Dynex-DX-LTDVD22-TVs-manual/id/23122dj497/t/2/
Above is a manual link. usually you use multiple presses on the buttons to get to the menus. One button, is menu, the others are for up.down & left/Right. The same as for Horz Posn. You press the menu, use the L/R buttons to go to the menu item, then up and down to + or - the setting.
have a look at the manual.
Apr 23, 2010 | Televison & Video
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
How do i adjust size of desktop background to fit screen
If you are using Windows Vista right mouse click on an empty area of the desktop and select personalize. Click on the tab for background and there are options there to fit to screen, stretch image, tile, etc. Select the stretch image and then apply. It will make the image fit your entire desktop. If you are using Windows XP it would basically be the same steps exceot when you right click you would select properties. Hope this helps.
Aug 09, 2009 | Computers & Internet
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
Onscreen Display is always ON
usually this is controlled from a small separate board you can find them on ebay for about 20 dollars.
Jun 22, 2008 | Samsung 793S 17" CRT Monitor
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
Computers & Internet Logo
82 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
