Question about Cooktops
My electrician examined the cooker and found that the main element has a hole burnt in it.
  • Cooktops Master
  • 12,061 Answers
This is a common problem and happens a lot. it is usually a flaw in the element that eventually burn a a hole right through it, and renders the element inoperative. They are relatively inexpensive to replace.
Posted on Aug 06, 2010
Why is my oven not heating up?
My guess is the heating element has gone. Get online and search your domestic appliance web sites quoting the make / model / serial number etc and see what element is needed. If you are capable of good DIY and know how to isolate the cooker then its not a big job to replace. I've googled your model and the elements are readily available. You don't say where you are but the elements are readily available in UK for between 20 and 30$. I had a similar problem with my double oven and found a suitable height table, covered in news paper, slid the oven out of the unit, changed the element, all done in under an hour. If yours is under worktop then slide onto a piece of board on blocks.
Jul 17, 2014 | Smeg Cooktops
Hi, I have a creda colonial range cooker. Yesterday I was using the fan oven and it tripped a fuse in the main fusebok of our house. I reset the fuse and now the 2 oveens wont work. The lights come on and...
All electrical appliance has a safety fuse located somewhere in the interior, most of the time it can be replaced.
always unplug electricity before attempting to repair on any electrical appliance
Sep 13, 2017 | Creda Colonial 42352 23 in. Electric...
On light comes on but burners don't get hot.
Dear friend,
sounds like your problem could be either burnt out element or wire to the element or both. I am qualified in saying this as i am an electrician & have experienced these problems many times in my busness.
Cheers
Jim.S.
Dec 25, 2010 | GE 30 in. Profile JP939 Electric Cooktop
The main burner (left front) only heats on half the circle.
Your referring to an electric range I'm assuming. In that case the heating element is only heating to a mid-point then stopping. This typically means the heating element is burnt or is partially burned out. The element is usually user replaceable and requires the old one be unpluggude and replaced with a new one. You'll need to get the element from the manufacturer.
Apr 21, 2010 | GE Cooktops
All 4 elements suddenly won't heat--worked fine this am. Circuit breaker was tripped. Reset, now lights on knobs come on, but still no heating.
Likely a short in the junction box. Turn off the breaker and open the junction box for inspection. Problem is likely at the cooktop end of the feed from the breaker.
Check voltage at the junction. Should one side of the corcuit be dead, turn off power and call an electrician as the wiring probably has had a short due to staple or nail penetration and would be a fir hazard. Call an electrician if this is the case.
Jan 12, 2010 | Jenn-Air JED8430 Electric Cooktop
No power to cooktop and breaker isnt tripped
maybe reason breaker kept blowing was a faulty cooktop
Nov 07, 2017 | GE 30 in. JP340 Electric Cooktop
ELEMENT ON ELECTRIC COOKER NOT HEATING UP
If it is a single element then either the element has gone open circuit or the switch has.
If all of the elements will not come on then it is the common supply to the switches which has failed
To track it you need someone who knows how to use a multimeter or a voltage tester
Do not poke around inside it yourself as it carries full mains voltage
Jun 04, 2009 | Cooktops
Jenn-aire downdraft electric heating problem
Be sure the control is set to F* and not C*.
Aug 12, 2017 | Jenn-Air JED8230 Electric Cooktop
Cooktops Logo
656 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
