Hello, My AEG 50840 finishes the processes but is not always switching to "end" status and I cannot open the machine. What is possible reason? Thanks in advance, Nahum
4 Suggested Answers
  • 1294 Answers
SOURCE: aeg lavamat 538
Your door will not open if there is water still in the machine. Try "spin only". If this fails, get a bucket, remove your outlet tube from the wall drain, put into bucket. Wall plug off first. After all the water is drained try the door, do not force it.
Then check your outlet filter; the water does not go thru for there may be a block in your filter, or tube from the tub to drain area. Or finally in your pump. Dont forget to refix drain pipe in wall in exact position.
And rate me pl.
Posted on Dec 01, 2007
Benimur
  • 6966 Answers
SOURCE: AEG Washing Machine: Door won't close
Hi again,
Any updates/development with your project?
Posted on Jun 21, 2008
SOURCE: Machine doesn't start washing process
mine fille up with water puttaht is a far as it getes
Posted on May 22, 2009
When I switch on my washing machine AEG Lavamat turbo 16800 it displays E40
HI Mike.
THIS IS ALL I COULD FIND OUT.
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.
to solve the problem get another switch.
hope this helps you.
or read up some more at this link.
washing machine AEG Lavamat turbo 16800 it displays E40 Google Search
Dec 20, 2017 | AEG Washing Machines
I have AEG Lavamat 60210 Front Load Washer machine. The machine stops after some cycles and time on the screen return to start. The Problem I get is E52.
Intervention of motor overheating safety cut-out.
Possible fault Motor faulty; Intervention of motor overheating cutout; Wiring faulty; Electronic board faulty.
Machine Status/Action Power to the heater unit and reversal of the direction of rotation are interrupted. If the problem does not re-occur, the alarm is memorized and the cycle continues. If the fault persists after several attempts to supply power (about 35 min.), alarm E51 is generated.
Oct 23, 2016 | AEG Washing Machines
I have a aeg washer/dryer- it washes fine but then I have problems drying Any idea how I can solve this? problem
Please start with your clothes after the washer finishes it's washing cycle.
Take them out and see how dry they are.
They should be nearly dry.
If not, perhaps the reason you are having problems is they are too wet to begin with for the dryer to properly do it's job..
This is not a rare problem.
One possible reason for the clothes not to be dry when the washer finishes is a loose or worn out belt under the washer.
Another problem some washers have, particularly washer/dryer combos, is that they are sometimes not very effective.
In that case, either smaller loads or rerunning the spin cycle at the end of the washing cycle might help you.
God bless your efforts.
Nov 30, 2015 | AEG Washing Machines
AEG OKO FAVORITE 4070 - AFter not using for a week dishwasher is flashing dry & end together, will not switch off unless turn it off at the power point, there is no water left in the machine.
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
Mar 16, 2014 | AEG 24 in. Favorit 60870M Free-standing...
AEG Lavamat 74800: Door doesn't open, i.e. opens with long delay
Following next link:
How washing machine door lock works how to test interlocks
Replace door lock.
untitled2-rq2y3fnvghvfrpvxa33jafnd-1-0.jpg When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5) is powered by the triac on the PCB (J6-2 connector): after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed).
The door interlock prevents aperture of the door while the appliance is in operation.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
Certain models feature a pilot lamp which lights to indicate that the door is locked. This pilot lamp switches off when the door can be opened.
Dado
Mar 17, 2017 | AEG Lavamat 72640 Front Load Washer
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Mar 24, 2008 | AEG Washing Machines
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
regards,
Alf
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
AEG L1250 Washing Machine
possible interlock, the switch that stops it from working when the door / lid is open start here
Oct 01, 2007 | AEG LW1250 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
