Question about Linksys Wireless-G Broadband Router
I hanve an old model on LINKSYS wireless G accesspoint with only 1 hub for UTP port. Here's my problem regarding in putting a password on it. Firt I connect the wireless G access point to my computer using the UTP wire for lan to create a password for my access point. But it shows that the wireless was not successfully connected to my computer or it shows the message that it is no connectivity, but when i tried using it thru wireless connection, ofcourse I connected to my modem then i function will. But it has an disadvantage because my connetion is open and everyone is using without any permission. so, may i know any solution to set up the password on this access point.?
    President:
  • 1,768 Answers
Your issue is simple to solve. You are trying to use an "access point "
Posted on Aug 06, 2010
My acer aspire one netbook will not connect with my new linksys e2000 router.. It was fine with my former linksys router
If your former linksys router was NOT N but rather b/g, then the problem is likely that your new router is running N and must be reconfigured to run b/g instead of n on its wireless. The acer aspire one netbook's integrated WiFi is 802.11b/g and the only way to do 802.11n is by using a plug-in USB 802.11n wireless adapter. To manually configure the router's wireless for 802.11b/g or n...
1. Connect the netbook using an ethernet utp cat5 patch cable between one of the four RJ-45 LAN ports on the router to the 10/100 ethernet RJ-45 port on the netbook's left side.
2. Start a browser like Internet Explorer and enter IP address 192.168.1.1 (default for Linksys)
3. On the login window, enter admin for username and admin for default password, then click OK
(The password may be changed if the router's setup software on its CD has been run.)
4. On the Linksys Setup page, click the Wireless tab
5. On the Linksys Wireless page, for Network Mode, click v for drop menu and click BG-Mixed
The preceding is from Chapter 3: Advanced Configuration which starts at page 16 of the 59-page Linksys E2000 user guide/manual. If you are missing this manual, it can be obtained by clicking...
http://homedownloads.cisco.com/downloads/userguide/E2000_UG_USA_V10_NC-WEB.pdf
A final note: The easiest way to setup the router is to run its setup software on the CD that comes with it. If you want to do this with the netbook (which doesn't have an internal CD drive), an external CD drive would have to be plugged into one of its USB ports.
Jan 25, 2011 | Cisco Linksys E2000 Advanced WirelessN...
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Can u help me retrieve my wifi password?
You need to do a factory reset of your wireless router. This should clear the password in it. There is no password for your 5-port switch.
Nov 18, 2009 | Linksys EZXS55W EtherFast 10/100 5-Port...
How do you manually connect a computer to the router? Trying different cables in port 1 but does not register to the computer. Please help!
You need to connect a standard network patch cable between port 1 and the ethernat port on your computer. To access the Web-based Utility, launch Internet Explorer, and enter the Router’s default IP address, 192.168.1.1, in the Address field. Then press Enter. This should bring up the router confiuration web page.
The password request page should appear. Leave the User Name field blank. The first time you open the Web-based Utility, use the default password admin.(You can set a new password from the Administration tab’s Management screen.) Then click the OK button.
Nov 08, 2009 | Linksys Wireless-G WRT54G Router
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
STP cables - with - Linksys Ethernet 5-Port Workgroup Hub
Most liklely you shouldn't do this unelss you are willing to do the work to properly ground the cables on each end. I'm pretty sure your hub iuses a DC power brick so it won't handle it for youm you'll have to build a breakout box of some sort to do this. Remember that if the cable isn't grounded properly on each end it will actually make things worse.
Running at 10M with Cat 6 cable it is highly unlikely that you will have issues with electrical interferecne even with the the undesirable routing of the cables in your house.
Aug 21, 2009 | Computers & Internet
Un secured linksys router
first need to reset your router push the reset button at the back of the router for for 10 sec. then open internet explorer type 192.1681.1. enter type password admin enter ,..configure again your router enter the IP address. , Subnet mask , and DNS put the setting Static IP ,next click mac address clone and click "clone your pc mac" then click wireless at wireless network mode put it mix, at wireless channel put to the highest ghz. then after that check your line by trying to conect to the other pc using your UTP cable if it is working connect it again to your laptop
Jun 23, 2008 | Linksys Wireless-G WRT54G Router
Port switch problem
Binz, have you tried doing a hard reset on the router, hold the reset button 30 seconds, login in will be user: admin password:admin -- if its an older model user blank password:admin, if that doesnt work, try updating your firmware, you didnt specify your router model, or I would link you to a firmware update
Aug 28, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Linksys Wireless-G Broadband Router Logo
46 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
