Question about Acer AC713 17" CRT Monitor
AC 715 17"CRT NOT POWERING ON. - Acer AC713 17" CRT Monitor
    Problem Solver:
  • 5 Answers
May the fuse of your monitor got disconnect or died.
just replace a new fuse.
Posted on Aug 06, 2010
My CTK 720 isn't powering on from the adapter anymore but battery power is working. I bought a new adapter but it still isn't powering on. Can this be repaired?
This could be a loose plug inside the unit or it could be a circuit that is bad. If the plug failed it is from physical damage from something like tripping over it or heavy use. That can be repaired by replacing the plug. If it is something like a component in the unit on a board then it becomes a little more involved.
Mar 26, 2016 | Casio CTK-720 Electronic Keyboard with...
Hp pavillion lighitng bolt led on front keeps flashing and will not power on
I see that you said that you "powering on the AC adapter only".
Does that mean you tried booting with the battery removed?
If not, completely remove the battery and try to boot.
If that fails too, it will be a switch or board issue
Mar 12, 2013 | Computers & Internet
I have a Dell Latitude D800. I want to run it on AC power. Do I have to take the battery pack out of it before I ru it on AC power?
Hello Paula, Hi Never remove the battery out when powering with AC, your Dell will get busted, run ac with the battery. The AC power produces a voltage above the normal operating voltage of the Dell, the over voltage is for charging the battery and powering the DELL, if you remove the battery, the over voltage will bust the laptop in seconds. So operate the laptop with AC and battery.
Feb 11, 2011 | Computers & Internet
WONT POWER UP
First you shoult remove the battery (it could be short circuited) then try powering up, if it's not working check the AC adaptor with a multimeter to verify voltage (compare with what it is ritten on the AC adaptor) last thing you should remove everything you can (RAM, HARD DRIVE, NIC's, CD ROM, etc...) than try powering up again if it power's up than put back ONE DEVICE/MODULE AT A TIME TO TARGET THE FAULTY DEVICE. if nothing worked i'm sorry it's dead.
Jan 04, 2011 | Toshiba Satellite M65-S821 Notebook
My acer aspire 1642 is not turning on.....
It can be1 of 4 things, the two most common issues is that the AC adapter is not powering up the unit, or the power connection on your notebook is broken. Either the Ac adapter will need replacing or your main board.
second possibility, is that the battery is shorting out the notebook, try removing it and powering it up with the AC adapter to see if it turns on, if thats the case, purchase a new battery.
lastly, it could be a bad power switch or mainboard, which will need to be sent in for repair as well.
thanks
May 29, 2010 | Computers & Internet
Not powering up. The LED power light is just flashing when the battery is in.when the battery is taken out it remains lighted up but goes out when the power switch is pressed.
Try draining the static of the computer.
Turn off the system
remove the AC Adapter and all 3rd party devices if there is?
Remove the battery
press and hold the power button for 1 minute
then,
plugged back in the AC Adapter and battery
turned on the computer
May 19, 2010 | HP Mini 1140NR Netbook
Keeps powering on and off.
Keep in mind since you cleaned it out, only have the AC adaptor hooked up to rule the battery out. If the laptop stays on with only the ac adaptor hooked up and doesn't shut off then you know that the battery is faulty. If it still shuts off even with just the ac adaptor hooked up then it could be the ac adaptor.
Also check one more thing, with only the ac adaptor hooked up, wiggle the cord where it plugs into the laptop and see if the laptop shuts off, if it does then the dc jack on the motherboard is loose and needs to be resoldered back into place so it stays put.
May 13, 2009 | Dell Computers & Internet
Acer AC713 17" CRT Monitor Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
