Question about Vacuums
I have an Electric Body Scale (QIE-2003B). I GET AN ERROR - ErrH, and cant use the scale.
Weight watchers electronic scale showed overload after I inserted batteries. Now the scale is no good. I never got to use it. What can I do?
The scale is not able to find ZERO and this can be checked by looking at the feet and see if any are stuck down, they have sensors in the feet and the unit checks and calibrates the sensors when it is powered on. .See if you can pull on the legs a little bit and then try it again.
Sep 11, 2017 | Vacuums
How to repair
A wire might have come loose inside the Vacuum head.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
Remove/Dismantle the Vacuum head and locate the wires.
Check the wires at the terminals and at pinch points
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 08, 2014 | Hoover S3670 WindTunnel Bagged Canister...
U5445-900
This is a good start, try this link...
Product Manual Search
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 02, 2014 | Hoover U6630-900 WindTunnel Bagless...
My hoover vacuum does not power up
Here s a link to the manual
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 15, 2014 | Hoover S3330 / S3332 Straight Suction...
How to replace power cable on hoover jc3157t
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 04, 2014 | Hoover Vacuums
I have two Weight Watcher scales, model WW11D. They weigh 4 lbs differently. One is 2 lbs heavy and the other is 2 lbs light relative to the weight registered at a Weight Watchers meeting. Is there a...
You say, that: "I have two Weight Watcher scales, model WW11D."
Can I have three guesses where you purchased them???
Do they come with any sort of warranty?
Their weight is inaccurate as compared to the official scales when you weigh yourself at the Weight Watchers meeting.
Are the people running the Weight Watchers meetings absolutely and totally unable to provide an answer regarding these scales?
Jul 04, 2011 | Vacuums
I just need to get a copy of the instructions for the 5758BL Biggest Loser Scales.
Taylor has a number of scales available in The Biggest Loser series for which they make available a link to the Instruction Manuals. See here:
http://www.taylorusa.com/catalogsearch/result/?q=biggest+loser&x=0&y=0
Here are two examples:
The Biggest Loser 7334 Weight Management Electronic Scale with Goal Tracking
http://www.taylorusa.com/media/IBs/7334_ib.pdf
Taylor The Biggest Loser 73343 Lithium Electronic Scale
http://www.taylorusa.com/the-biggest-loser-lithium-electronic-scale.html
Unfortunately after browsing their site I found nothing close to the model number you provided. If you see a model that is similar in looks and features suggest you see if the instructions for that model are of use to you. You may also find there FAQs to be of assistance:
http://www.taylorusa.com/faq-scales
Alernatively send an inquiry direct to Taylor Precision Products:
http://www.taylorusa.com/taylor-support
Apr 23, 2011 | Vacuums
My scunci handheld steamer does not dispence steam anymore
probably full of scale in the nozzle and element common from using tap water. Purchase a product called scale clean insert and flush. Scale clean is available at department stores for home coffee makers.
Sep 13, 2009 | Scunci 900 Handheld Steam Vacuum
Vacuums Logo
107 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
