Question about Microwave Ovens
Hi. I have a Panasonic Genius 1100 inverter oven. The lamp failed some time ago, but now the fan and turntable keep going even when finished cooking. Would this be a complex DPC problem? Could it be sticking switch or relay? Thanks for any ideas Bob
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel (such as a sticking relay).
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our
listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 02, 2008
My panasonic genius prestige inverter microwave has started to click off after I enter the power & time. Sometimes it will work fine. Sometimes it takes 2 or 3 times of entering then cleaing the i
Check the door latch switch inside the oven. The 4 switches where the door hooks latch on to when the door is closed has to engage with the door hooks to tell the oven that the door is closed. loosen the 2 phillip screws that holds the switch assembly and slide it to adj. and ensure that the switches close when the door is closed.
Sometimes the switches go bad and cannot make contact and must be replaced. If you see that the connectors on the switch is discolored or overheated replace the switch, it is bad.
Jan 15, 2015 | Panasonic Genius Prestige Inverter...
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
MY EMERSON MW1119B STOPPED HEATING
Sounds like it's broken. Go for Panasonic next time, they make better microwaves. Here's one I was looking at http://bestmicrowavereview.com/panasonic-nn-sn651b-genius-1-2-cuft-1200-watt-sensor-microwave-review/
Jan 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
