Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a jd 2440 tractor with a 146 front end loader. Today when i was using the loader it stopped working right and oil started weeping from the loader hydraulic cylinders. I changed the hydraulic filter and checked connection between tractor and loader but problem persist
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
mattofilms
  • 110 Answers
SOURCE: I just purchased a 2440 john deere tractor it was
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
Posted on Jul 02, 2009
  • 8404 Answers
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
nova2nv
  • 197 Answers
SOURCE: cannot find where to add hydraulic fluid for the
Yes.
Posted on Feb 24, 2010
  • 468 Answers
SOURCE: i need to rebuild a hydraulic cylinder on a john
You'll have to use a spanner type of wrench and unscrew the end of the cylinder. Once it screws out, the ram will come out, and you will have access to all the seals to replace them.
Posted on Mar 16, 2010
Testimonial: "a spanner wrench is needed but it's not threaded. a snap ring must be removed through a small hole in the side then it slides apart"
Ford 7810 series 2 hydraulics have gone very slow have pressure tested tractor and it is OK until you rev it up the pressure goes oil sound like it is sergin in back end of tractor oil level OK ?
Best advice is for you to list this in Lawn and Garden or Construction equipment section for Tractors. There is a valve knob on a 4000 series that proportions hydraulic flow from more in back than front depending on the setting. If you have a front loader or if you have rear attachments you can get more action on the end you want. On a 4000 the knob is by the right heel of the driver. Could work like this for 7810.
Jul 20, 2017 | Ford Cars & Trucks
Have a JD 300 with front loader. The tractor will not go forward when the tractor is started. It has a reverser and will go backwards immedictely when started. If the weather is real hot it will take...
Hi, don't know if you have checked this but anyway if you hydraulic oil filter is clean there may be another sintered bronze filter in the sump of the hydraulic tank this could be patially blocked> don't know this particular machine but if it is partially blocked it may be that you will clean that or there is air in the hydraulic system. Hope this is of some help.
Steve
Sep 29, 2013 | John Deere Muffler 1010 Diesel Tractors
The hydraulic steel line on my 2010C bucket loader broke and I dumped a good amount of fluid before shutting everything off. Replaced line and filled tank up, everything worked fine for about 1/2 hour,...
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Sep 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD 301 industrial loader tractor Overheating
You may need to do a compression test on the engine to confirm whether or not the head-gasket needs to be replaced,that's where i would start if the thermostat is not the problem and the hydraulics are not loading up.Check for oil in the radiator or anti-freeze in the oil as well as for white smoke out of the exhaust,all are indicators of a bad head-gasket.
Jul 17, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Tractor Front end loader will not dump. JD 2320 tractor front end loader .
Could be a lot of things. Quoick coupling loose? Does the lever work from left to right? Is it stuck now and only work from front to back? There is a small lockout feature on it that keeps from it moving when you hit it with your legs. It is down at the base of the lever. Other than that has to be connections. Try swithching the hoses around where up and down is dump.
See if its that
May 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD Lawn Tractor L130. will not start
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
May 10, 2009 | Garden
2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
345 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
