I have a Whirlpool ultimate care 2. The machine stops during the spin cylce and makes a humming noise
  • jshinstock Sep 12, 2008
    I have a similar problem. The Washer will fill with water then stop the cycle and start the humming / clicking noise (sounds like a timer). I can advance it to a difference cycle and get it to drain and I have ran it empty through the entire cycle but it's not 100% repeatable. I think it's the timing but difficult to confirm.
  • Ryan Brais
    Ryan Brais Jan 06, 2009
    My Ultimate Care II will stop after the agitation cycle on the normal setting and will not drain. I switched it to the rinse cycle on a different setting (gentle) and it drained and finished the load. The timer makes a loud humm when it stopps working and there is a faint electrical smell. Seems like a dead spot in the timer. I need an idea of what it will take to replace it.
    Genius:
  • 1,028 Answers
Ck motor connections make sure pump turns free possible timer internal motor connections bad
Posted on Apr 27, 2008
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool washer and it will not spin
The problem will be in the main board or the spinning coil may be short circuited, You can easily check the motor during the spinning process you will find the humming noise if you do not found any humming noise kindly replace the board
Dec 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Noise during spin
You have something stuck in the drain pump.
Remove the pump and clear the debris.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Humming noise during spin cycle
Strangely enough, the electronics in the motor drive circuits are quite hardy. Suggest if motor does agitate but not spin, check the motor brushes and see what length and condition they are in.Have had to replace brushes on many occasion.If you have a motor that has a capacitor then check the cap. It could be defective.
Feb 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
