Hello..my UPS was fully discharged and packed upto 2months, 2 months ago , i was taking 20 min backup from it.but now its not giving any backup when power off.....plz suggest..
  • 39 Answers
It sounds like the batteries were damaged. With the sealed lead acid type battery that are in a UPS it is best to keep them fully charged as often as possible. When the batteries are discharged too low then sulfation builds up on the lead plates inside and they wont take a charge. If you need to find batteries go to:
http://www.batteryinternational.com/ups-batteries.html
Posted on Nov 11, 2010
    Guru:
  • 825 Answers
Hold the reset button on UPS for 30secs while the power is turned on...
Then keep the UPS on charge for 16 hours with no load...
then check for the backup... while you shut down the computer you should not turn off the power supply to UPS...
Posted on Aug 06, 2010
WHAT IS THE PROBLEM BECAUSE, MY UPS IS NOT GIVING BACKUP POWER SUPPY, AND CONTINIOUSLY BIPPING WHEN POWER GOES OFF ?
The battery in the unit may need to be replaced. Usually it is a 12Volt 7Ah high discharge, Sealed Lead Acid Battery.
They life span is around 2-5 Years.
Take care!
damnor01
Apr 28, 2012 | Computers & Internet
La bateria no mantiene carga apena dura 20 minutos
buy a 6ah 12 volts battery and replace it wil give 20 mins
Jun 16, 2011 | MGE UPS Pulsar Ellipse 300 (89301) UPS...
My ups is not giving backup?
The main reason for not giving backup is improper charging or insufficient charging. Or if the UPS is about 18-20 months old, the battery is unable to give backup. or these are not the cases, the wires inside the ups, above the battery ,connected to the +ve and -ve ports on the above or side of battery are not properly connected or are loosen. try to tighten them with yourself with a plier or goto a shop for a better result. Hope this will help. Thanks for using Fixya.
Nov 17, 2010 | Computers & Internet
Battery backup time is 1 min when capacity is 100%(4 months older
The Batteries are the most likely course of your UPS backup problem. The batteries cell may have been weaken with Age or loose contacts. Check to confirm the battery contacts are not loose, replace the batteries with good one.You can also check the strenght of the batteries by using a Multimeter and load to read the voltage of the batteries outside the UPS. If the battery voltage drops below 10V Dc on load the the batteries should be replace. Otherwise check the battery contacts.
Jun 04, 2010 | APC Computers & Internet
Unit came to me brand new... The Power will not come on or power up? Checked the outlet..it is hot?
Check the batteries. If they are not fully charged, it will not come on. These systems use 2 6v batteries in series to make 12v.
Mar 12, 2010 | Tripp Lite (OMNIVSINT1000) UPS System
My kin-1200 ap doesn't charge the battery properly.
The reason for this is that the UPS, is unable to efficiently charge those BIG batteries, you see they generally only charge at a low rate, anyway, of say 10% - 15% capacity, of the-battery-usually-charged. Now with these BIG 40 Amperes by 2, well, there simply isn't enough "Juice" to charge them up... (Oh it might do in a month or so)... from that UPS's Charging Circuit. You will most likely have to rig up some other higher rate charger for those BIG batteries. OR modify the charging circuit IN the UPS. They need to be charged at about 1 Amp or maybe more. See it is simply Charge over Time... 40 amps at 1 Amp will take 40 hours.. 40A at 2A = 20H & so on. If only 1/2 flat 2A over 10hours.
Feb 07, 2010 | Powercom King Pro UPS System
How to charge the ups
hi, i think your ups batteries batteries are discharging very fast, you need to replace them with new ones, also with some systems it is possible to add more external batteries resulting to more back up time. check in the manuals to see whether its is possible with your system.
Oct 25, 2009 | Powercom Computers & Internet
UPS does not stand for 30 min
old and outdated get a new one used ones always have bad batteries but if you must get model number and search online may take a while but peruse through all the site thatsound promising and usually whalla
May 18, 2009 | APC Back-UPS CS 500VA UPS System
Battery charging problem
well, the charging voltage is the right one, you may have a problem with charger board, did you check that? tbe 2 big capacitators, maybe you will need to change them, there could be a couple of things, and to be honest i don´t have the circuits sheets, cause i stopped working with powerware.
good luck.
Jul 29, 2008 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
Alun Cox
David Payne
David Payne
