Question about Samsung (MP0804H) 80 GB Hard Drive
MY HARD DISK 80 GB DAMEGE AND I WANT TO WARRRENT TO MY HARDISK
  • rajeshchaube Aug 06, 2010
    sp0812c
    s\n so1uj1oy460061
    Guru:
  • 825 Answers
If there is a physical damage on your hard disk then it will not cover under warranty...
If there is no physical damage then you will get a 5 years warranty...
Posted on Aug 06, 2010
Pc cant see my disk go edge 80gb
Hi and welcome to Fixyah,
The problem that you having was the enclosure of your Hardisk and the need to exchange it. I suggest to you if ever that is under warranty sentit back to your reseller or take the disc out and buy another enclosure for you to be able to get all your files.
Aug 11, 2010 | EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard...
I could not hardisk detect on pc when decting hardisk,please boot another disk
Check that the "data" and "power" cables to the disk-drive are fully-connected to the disk-drive.
Check that the "data" cable is fully-connected to the motherboard.
Enter BIOS SETUP, and check that the motherboard has detected the disk-drive.
Otherwise, your disk-drive has "died", and must be replaced.
Aug 01, 2010 | Samsung (SP1203N) 120 GB Hard Drive
Hard drive on my computer is reporting 75MB left on a 20 gig drive with only word and a couple smaller programs on it - someone please give me an idea.
Hi!
Let's see how much left on your hardisk and how much space that your programs used in your disk..do this..
Double click the "My Computer" icon
Right click on your "Local Disk (C:)" drive and click properties...
The blue color indicator will tell you how much space was used by your programs on your hardisk..
The pink color indicator will tell you how much free space left on your hardisk
The capacity value should be more or less 19 GB..
See if this capacity value match in your drive..
If the capacity value of your drive is below 10 GB then my guess is you have a wrong setting for your hardisk... Look physically in your hardisk. Between the port of ide cable and power supply connector you will see terminals with jumper on it.. The jumper is used to short the terminal. the function of the terminal is to assign the hardisk as slave, master, cable connector and or limit the capacity of the hardisk to some amount.. Check the label of the hardisk.. schematic diagram on it will explain where to put the jumper...
If the setting of the jumper was correct and the capacity value of your drive match to approximately 19 GB... then I suggest you browse the files on your drive. Check all its sizes.. There could be movies there that eats your space.
I hope I explained to you everything you need to know..
Much appreciated if you rate this help.. thanks
May 22, 2010 | Maxtor Hard Drive
I cannot install software
Hi..
This happen due to 3 reasons,
The Hard drive is bad.
The BIOS Setting have to be put to SATA.
During the the installation the have to press the F6 option to install the SATA drive drivers.
Let me know
Thanks
Smith
Aug 09, 2009 | ASUS P5LD2-VM Motherboard
Fault in my hardisk
then contact the harddrive's manufactuer it shound have a number on the harddrive itself
Apr 05, 2009 | Samsung (SP0822N) 80 GB Hard Drive
MOBILE HARDISK IS 40 GB.HARDDISK PROBLEM IS DATA CAN NOT COPY FROM MOBILE HARDDISK OR PASTE IN MOBILE HARDDISK. HARDDISK SERIEL NO:-Q2KXOPE. HARDISK MANUFACTURING DATE:- OCT-06.
Maybe your hard disk is locked. Or kindly look at the properties of the Hard Disk see if the Read Only option is unchecked.
thanks
Mar 22, 2009 | Computers & Internet
Hard disk can not detect and giving beep randomly. hard diisk is from seagate and capacity is 80 gb
Hello there..i have experience with same problem like this...there is two problem with hardisk: first with the mechanic platter inside your hardisk ( you can hear noisy sound from inside HDD) 'cause by wrong prosedure when turn off the pc or problem with chipset on hardisk board (you can see the small green pcb board at other side of your hard disk) touch that board...if feel hot yes there is problem.this problem cause by electrical shock from your power supply unit or you not plugin correctly to hdd power socket.
solution for first problem :
send it to nearest seagate 'cause they have all the parts that you need
solution for second problem:
replacle the board with same tipe and size of your hdd..and it will work again and you can safe your data.but if not...nothing you can do it
Best Regrad
SHOGUN 125
Jan 21, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Removing bad secter from hdd
there are vaious ways
if u know how to make it slave hdd make it one by one on any desktop and run a disk defrag and scan along wd the consistancy check it is a time consuming process
ill suggest to format them it will take 20 min/hdd
May 19, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Toshiba MK8025GAS 80 GB Hard
hi rezwann,try using different jumper setting on ur hardisk it might work.
raj
May 11, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
Samsung (MP0804H) 80 GB Hard Drive Logo
55 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
