Where can i download a behringer uca 200 driver/
    President:
  • 1,285 Answers
  • http://www.behringer.com/EN/Support/Downloads-and-Drivers.aspx
hope this helps
Posted on Aug 06, 2010
There is a constant high pitch noise on the left input channel.
Sounds like you may have a defective unit. I would return it for exchange.
Oct 29, 2015 | Behringer (UCA202) Sound Card
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
The cd with behringer for w xp i wanna install cd for w7
You can download suitable drivers from Behringer's site. Are you using the 32- or 64-bit version of Windows 7?
BEHRINGER Control Downloads
Once you've done that:
  • Uninstall the existing Xenyx drivers.
  • Unplug all USB devices except mouse and keyboard and then in Device Manager delete all your USB hubs.
  • Reboot. Let Windows find and install the USB hubs.
Install the drivers you downloaded from the Behringer website.
  • Plug in your Xenyx. Windows 7 will install the drivers and you should have a signal.
  • Make sure you select the unit is input and output default in control panel.
Mar 15, 2013 | Behringer XENYX X1204USB 12-Channel Mixer
Super usb cassette capture
You have to convert the cassette's analog audio to digital. Get a Behringer UCA 202 for $30 on Amazon.
Aug 20, 2012 | Audio Players & Recorders
My U-CONTROL UCA200 is not recognized by Macbook Pro (OS X Lion). I can't find its driver available. Please help.
You can download the driver for UCA devices at Behringer.com
Click on "Support" in upper portion of the screen, to the left you will see Downloads and Drivers, go to XENYX/U-Control Downloads, download the "BEHRINGER_2902" (32 or 64 version depending on your processor). Unzip it, install and enjoy.
Aug 20, 2011 | Behringer (UCA202) Sound Card
Cannot find the driver of fca202 behringer for window7
BEHRINGER FCA202 - Driver version 1.3 for Windows XP (32-bit), Windows Vista (32-bit), and Windows 7 (32-bit) may be downloaded from the attached file. After downloading and decompressing ('unzipping') the download file with WinZip or other compatible utility, run the resulting .exe installer file to install the driver package.
http://behringer-en.custhelp.com/ci/fattach/get/44010/1269637577/session/L2F2LzEvdGltZS8xMzA0NzIyNDEzL3NpZC9VcGxZWWl0aw==
hope this helps
May 06, 2011 | Behringer F-CONTROL AUDIO FCA202 External...
I dont know how to connect it to my laptop
I'd recommend either the UCA 202 or the UCA 222. Both are Behringer products and the 222 comes with a software bundle. Check out the energy XTC software, I downloaded it and am having fun with it already.
May 09, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer uca 202 not recording
i also had trouble at first,and fought with it all the time! as it is not a great item. my recording software could not set it up, as it is not actual hardware.(audio codec) make sure the controls are not muted and the slide bars are set upwards. also the drivers from behringer are not signed! and could cause stability issue. you may want to do as i did and get a better unit, (about 20 bucks more) hope this info helps, good luck!
Dec 27, 2008 | Behringer (UCA202) Sound Card
Driver
is there any support for windows 7 64 bit? my behringer model is fca 202?
Oct 22, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
How to use
the best way is to connect your master output to the uca200 input and uca out to your amp. u have to use a sound editing software to record.suggestions-audacity.
Yours DjNicq
Jul 21, 2008 | Behringer (UCA202) Sound Card
Computers & Internet Logo
1,736 people viewed this question
Alun Cox
David Payne
David Payne
