Question about Jabra BT150 Wireless Headset
My jabra bt150 won't turn on even after charging. what should I do to troubleshoot my device?
whitetiger93
  • 141 Answers
SOURCE: Jabra BT150 No power
Make sure the charger is in right. If you put it on wrong you will get a faint blue light, when it is in right you will get a BRIGHT BLUE LIGHT. It WILL NOT charge if it is in wrong.
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Link for manual
Posted on Mar 29, 2008
micromatikal
  • 2777 Answers
SOURCE: I cant get my jabra
Unfortunately you can't really replace the battery in that unit, once it dies it's pretty much gone. You would need to break open the case to get to the battery which of course renders the whole piece useless. On top of that a new battery would be around $15 for that style battery, and you can get a whole brand new "Samsung" bluetooth unit for $17.89 with free shipping here:
http://www.amazon.com/gp/product/B001UCELX4?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001UCELX4
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Posted on Oct 14, 2010
informatica
  • 1114 Answers
SOURCE: Manual for Jabra BT150 ????
You can download the manual & get other information from the link below: http://web.jabra.com/JabraCMS/EM/EN/MainMenu/Support/WirelessHeadsets/JabraBT150/ Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 12, 2007
SOURCE: Jabra BT150 head set not turning on
did you ever get it fixed?
Posted on Jan 01, 2008
SOURCE: Jabra BT150
Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
Pairing code 0000
DO NOT PRESS (-) key
Posted on May 15, 2008
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
How do i charge my jabra bt150
Use the AC adapter to charge from a power socket.
The charging socket is located at the top of the headset (the wider end). When the LED is solid blue, your headset is charging. When the solid blue LED turns off, it is fully charged.
Sep 27, 2010 | Jabra BT150 Wireless Headset
I cannot connect my handset.
Turn on your cellphone's bluetooth, try searching for a new device. If found, select Jabra BT150 and enter default passcode "0000". Nice bluetooth headset, Goodluck.
Dec 13, 2008 | Jabra BT150 Wireless Headset
How to conf jabra bt150 bluetooth for nokia n73
switch jabra off. switch cell on. turn bluetooth on. press "right hand" button next to middle button on cell to search for bluetooth devices. Hold down on switch and volume up switch TOGETHER on jabra. The cell then finds the jabra. I couldn't do this before I found Marie's problem below. Thanks for the info Marie!
Nov 29, 2008 | Jabra BT150 Wireless Headset
Lost instructions BT150 how to connect to phone?
1. Turn the BT150 on. To do this press and hold the answer/end button until the light flashes blue, then release.
2. Press and hold the answer/end button and the volume up (+) button until you receive solid blue light. This may take up to 10 seconds.
3. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Goodluck
Apr 27, 2008 | Jabra BT150 Wireless Headset
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Link for manual
Mar 22, 2007 | Jabra BT150 Wireless Headset
Setting up pairing
# Fully charge your Jabra BT150 and switch on by pressing the answer/end button # Press the answer/end button and the volume up (+) button together, to put the Jabra BT150 in pairing mode # Set your mobile phone to ?discover a Bluetooth device? (see your phone user guide) # Press Yes or OK when asked if you want to pair the phone with the Jabra BT150 # Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK # Your phone will confi rm when pairing is complete
Jan 05, 2007 | Jabra BT150 Wireless Headset
Jabra BT150 Wireless Headset Logo
478 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
