Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Missing a part to my saw and not sure what the part name is??? it is the piece at front of saw with the spiked teeth that hits up against the log instead of hitting up against saw casing....
  • 252 Answers
Ask for the bucking spike for your model that attaches to cases or sprocket/ chain brake cover ( fits over the bar studs )
cheers
Posted on Aug 06, 2010
After using anew chaini hit dirt. isharpenit withadifferntanglewillthat make a differencein cutting.
sure will , most saws have different angle cuts to teeth on blade this "angle" needs to be maintained as the "rake" teeth that are behind the cut teeth are set to provide a good way to wipe out cut debris (cut,rake,cut,etc.) this is how chain cuts thru wood , if one changes the cut angle on teeth the rake teeth might not do there job correct and saw bogs and "files" thru wood rather than chips thru wood ,takes longer ,more fuel, more effort , a look at saw cuttings tells the tale , more tiny file sawdust = dull chain --- large Chips and less dust = sharp chain
Aug 26, 2015 | Garden
When cutting 7.5" laminate wood floor with 12" miter saw. When we cut, the very end of wood(1.25"at the same place on every piece). Does this mean blade is dull?
Hi Shaun:
Just a couple of things to try:
- Make sure the laminate is supported at both sides when cutting.
- Make sure the laminate is held firmly against the fence and deck when cutting.
- Do not "rush" the cut. Laminate is very hard and does not like to be hurried.
- Make sure that the correct blade (teeth) is being used.
- And yes, the blade has to be SHARP
Jul 25, 2015 | Saws
Screeches when I cut wood
open the front and watch it when you turn on sounds like you have a piece of wood stuck somewhere
Apr 01, 2015 | Central Machinery 9" Bench Top Band Saw
Square up fence to blade
with the tool unplugged from power . u need a good square drop the blade down to cutting position place thesquare against the fence then slide it up to the teeth on the blade making sure u are against the teeth . if not square in the zero position on the scale undo the fixing bolts for the fence and adjust till the square shows no gap between fence and blade teeth . retighten bolts and check . plug in and make a cut . or u could just make cuts and move fence till get it right . i should add with straight edge make sure the fence itself is straight across its face. with one piece fences they can get bent. good luck.
Aug 14, 2011 | Makita 10" Miter Saw LS1030N
How can i install the blade a friend of mine gave this as a gift and i could not find the lock to stop the nut from moving to loosen it
If the saw does not have a lock, you "jam" a piece of wood against the teeth to keep it from turning while loosening/tightening the bolt. Some are left hand threads...
Jun 12, 2011 | Skil 5470-01-RT Factory-Reconditioned...
How do I lock the motor in to remove bolt and replace blade
If there is not a built in lock for the motor simply use a scrap piece of wood. Pull back the blade guard and place the saw on the piece of wood with the teeth logged into the wood. Apply pressure downward on the teeth and remove the bolt holding the blade in place. You can also use a scrap piece of wood to wedge in the saw between the guard and the blade to prevent it from turning. Be careful and make sure you are turning the bolt in the correct direction.
Apr 16, 2010 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Engine ticks over but chain doesnt move
make sure the brake isn't on. The piece that is in front of your hand at the top of the saw should be pulled back until it clicks into place to release the brake. This is there so if the saw kicks back at you this piece will hit your hand and go forward and stop the chain before it hits you. Hope this helps...
Sep 02, 2009 | McCulloch Garden
Reciprocating saw problem
OK just looked at the Searspartsdirect.com website and there are 2 parts that I think it could possibly be. One is the SHOE part # 399725-00 list 4.86 in stock and or guard 157325-00 list 4.59 also in stock. I would suggest that you go to this site and confirm which one you need, but the shoe is the piece that does ride against the work surface. Good Luck and let me know if I can help further
Jan 17, 2009 | Craftsman 8.0 amp Reciprocating Saw
Chain saw cuts at an angle
I have seen this problem of a chain saw cutting at an angle brought up again and again on forums, and result in a variety of answers about sharpening the chain, or replacing the bar and/or chain. In a number of these requests for solutions, none of the advice has solved the problem. I have used chain saws for about 45 years now, and there is a condition that some chains develop with the pitch of the teeth or the guides...or both...that will cause them to cut to the left or right at an angle (usually left). While I have not figured out what causes this, I have solved the problem of correcting it. First, turn the nose of your bar and chain toward you on a bench, look down it like sighting a gun and take a look at each tooth and guide. If the saw is cutting left, the teeth or the guides (or both) on the left (while you are looking down the bar from its tip) will be pitched differently than the teeth and/or guides on the right. The pitch of those teeth or guides (those little ears that stick up about on-fourth inch in front of each tooth) will be: 1) too much in line with each other, or 2) the teeth or guides will be less pitched than the teeth or guides on the right side of the chain. Solution: take a large pair of lineman's pliers or similar pliers and pitch those teeth and guides to match those on the right side of the chain. Also, make sure the curved part of your chain teeth peek out around the outside edge of those guides. If the guides are directly in line with your teeth, they will hinder cutting by the teeth. You can do this with the chain on the saw if you don't have too much slack between the bar and the chain. Last, make sure that the chain guides are not as tall or taller than your teeth. If they are, you will need to file them down a little (with a flat file) until the teeth are slightly longer than the guides. Afterward, make sure the teeth on both sides are equally sharp, and go cut a straight cut! TennesseeBob
Jan 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
