Question about KitchenAid Dishwashers
I have a kitchen aid dishwasher that is stuck on the clean cycle. It will drain water, but no water seems to be getting into the washer. If i push the start button, cycle will not start. The clean light is the only light that will stay on. the other lights will go on, but they eventually go off without starting the cycle. Is this the thermal fuse???
    Habit-Forming:
    New Friend:
  • 73 Answers
You might have a problem with the water pump
Posted on Oct 05, 2017
  • 11 Answers
SOURCE: Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Posted on Mar 21, 2007
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Posted on May 09, 2008
  • 210 Answers
SOURCE: MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Posted on Jun 01, 2008
It says in the manual to check the heating element.
Posted on Sep 10, 2008
Kitchen Aid dishwasher won't start. All keypad buttons/lights appear to be functional.
The touch pads are common to go bad. It could be a bad start switch pad or bad control board.
Oct 05, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kitchen aid dishwasher
The washer is filled up with water because it is at float level. So basically same water to clean again and again. You will have to remove kick panel at the bottom front for access to the pump and drain hose.
Apr 24, 2013 | Dishwashers
Is there a way to get the water is described in the video out of this dishwasher. Kitchen aide w103111238
I like the way you call the fishies in your washer! Seriously, there are three probable causes. First, pull off the spinner, bottom plate and yank the filter screens. Clean them thoroughly and look for clogs below them. Next, look for the water level sensor that detects water in the bottom and keeps the flush pump running as long as there is. Make sure it cycles up and down. Finally, make sure you hear the pump running when the draining cycle starts...
Jan 10, 2013 | Dishwashers
Water in the bottom drawer
Take a glass and empty as much as possible. Take out the racks and get a towel to soak up the rest.
Take the washer arm out and detach the filter plate collar. Also take out the drain filter and clean everything. You could take the washer rotor out and clean the rotor cavity.
Put everything back and start the dishwasher on fast cycle. If water is still not draining and provided the pump is running, then you have a blockage in the drain hose or the kitchen sink end. If you are using inskerator then make sure it not blocked.
Jul 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Kitchen Aid Superba Dishwasher
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Dishwashers Logo
161 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
