Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Where is hydraulic filter located on IH 706 Tractor?
  • 18 Answers
Right hand side -teardrop shaped cover bolted to side of transmission should only lose a gallon or so of oil when changing
Posted on Nov 06, 2010
Where is transmission filter located on international 756
I t is behind teardrop shaped cover below r ight hand brake drum.
May 20, 2014 | Farmall IH Tractor 706, 756, 806, 856,...
Steering work when hot out
Clean hydraulic screen and replace filter and top off hydraulic oil.
Jan 05, 2014 | Farmall IH Tractor 706, 756, 806, 856,...
I have 706 Farmall tractor with the D310 engine and TA. When I baught it the transmission fluid was all milky with water and the TA and power steering did'nt work. So I changed the oil and filter and...
change hydraulic filter again and probibly the oil use ahigh quality hydraulic oil like Case-ih hytran fluid this oil has a high moisture retention factor be sure to drain all the cavitys 5 plugs total and let them drain completely before refilling
Apr 04, 2011 | Farmall IH Tractor 706, 756, 806, 856,...
When engaging PTO it takes a few seconds before engaging bought the tractor new have changed hyd filters regulary. Any suggestions?
hydraulic filters wont help since pto is self contained unit first of all check pto lockup pressure my best guess is that clutches are probably getting worn
Oct 11, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
I have a 1967-706 Farmall IH splitting a transmission
you must remove the plate from the bottom of the transmission. Look for a shaft that goes from the rear through a gear. Remove snap ring from in front of gear and it should roll apart then. On reassembly be sure to change gasket and all o rings to prevent hydraulic suction leaks
Jan 18, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
3,284 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
