Question about HP StorageWorks FCA 2384 (302784-B21) Network Adapter
Unable to access EVA3000 storage LUNS from HP ES47 alpha server running tru64 5.1b os. Dual channel point-point FCA is up. /var/adm/message log attched ug 4 21:30:53 gcmd-sector vmunix: cam_logger: hardware_id=209 bus 0 target 3 l un 7 Aug 4 21:30:53 gcmd-sector vmunix: cdisk_op_spin Aug 4 21:30:53 gcmd-sector vmunix: Device Not Ready Aug 4 21:30:53 gcmd-sector vmunix: Hard Error Detected Aug 4 21:30:53 gcmd-sector vmunix: Hardware ID = 209 Aug 4 21:30:53 gcmd-sector vmunix: HP HSV100 3028 Aug 4 21:30:53 gcmd-sector vmunix: Active CCB at time of error Aug 4 21:30:53 gcmd-sector vmunix: CCB request completed with an error Aug 4 21:30:53 gcmd-sector vmunix: cam_logger: SCSI event packet Aug 4 21:30:53 gcmd-sector vmunix: cam_logger: hardware_id=210 bus 0 target 2 l un 8 Aug 4 21:30:53 gcmd-sector vmunix: cdisk_op_spin Aug 4 21:30:53 gcmd-sector vmunix: Device Not Ready Aug 4 21:30:53 gcmd-sector vmunix: Hard Error Detected Aug 4 21:30:53 gcmd-sector vmunix: Hardware ID = 210 Aug 4 21:30:53 gcmd-sector vmunix: HP HSV100 3028 Aug 4 21:30:53 gcmd-sector vmunix: Active CCB at time of error Aug 4 21:30:53 gcmd-sector vmunix: CCB request completed with an error
SOURCE: eio device 3 disk not functional
Afraid you'll need to replace the hard disk:0(
Posted on Oct 25, 2007
SOURCE: c7280 hp all in one has failed the fax hardware test
I uninstalled and installed again and that seemed to have fixed the problem.
Posted on Dec 09, 2008
info2u
  • 596 Answers
SOURCE: SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Posted on Feb 09, 2009
  • 101 Answers
SOURCE: server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Posted on Mar 02, 2009
  • 194 Answers
SOURCE: Keyboard cannot be install on rebooting
uninstal the drivers of keyboard from device manager and restart the system
Posted on Aug 17, 2009
Sir, we have HP prolient windows 2003 server (standard edition ) SP2 we are using both LAN/WAN connection in some of the clients using dual IP address. All the client machines are running smoothly but...
hung.
it's virus infected.
OS corruption..
or has hardware issues (had disk going bad?)
why not get it serviced, by a tech.?
reload the OS? if it can't reload the HDD is bad or PSU .
May 16, 2017 | HP Compaq ProLiant ML370 G3 Server
How we enter the hp compaq Ml-350 server bios setting
At startup before OS is loaded you will be prompted to press F8 to enter system setup at this point press F8. This message only last a few second. If you didn't get it the first time reboot the system and pay attention to get this message.
May 24, 2010 | HP Compaq ProLiant ML530 Server
How to find area between 2 curves
The TI84Plus has a Shade( function which allows you to represent the area you want to calculate.
The simplest syntax of the command is
Shade( lower_function, upper_function, Xleft, Xright, pattern, patern_resol) where Xleft is the left limit, Xright is the right limit, pattern is the shading pattern and pattern_resol is the resolution of the shading. Only the area where lower_function is less than upper_function is shaded. Unfortunately this command does give the value of the shaded area.
To find the area between two curves
  1. Draw the curves
  2. Find the left intersection point using [2nd][CALC][5:intersect]. Sorry I will not describe the procedure. The X value of the intersection point is stored in Ans memory.
  3. Press [2nd][QUIT] to go to main calculator screen.
  4. Store the Ans result in say A: [2nd][Ans][STO->][ALPHA] A
  5. Return to the graph by pressing [GRAPH].
  6. Find a second intersection point. Result is stored in Ans memory.
  7. Press [2nd][Quit] to return to main calculator screen
  8. Press [2nd][Ans][STO->][ALPHA] B to store the X value of the second intersection point in B.
  9. Use the CATALOG to paste the fnInt( command to calculate the integral : [2nd][CATALOG][[APLHA] F and scroll to select fnInt( and press [ENTER]
  10. To complete the command you need the identifiers Y1 and Y2.. You access the identifiers Y1 and Y2 by pressing [VARS][Y-VARS][1:Function][1:Y1] and [VARS][Y-VARS][1:Function][2:Y2]
  11. The command should appear as fnInt( Y2-Y1,A,B)
  12. Press [ENTER] to obtain your value.
Hope it helps.
Thank you for using FixYa.
Do not forget to rate the solution.
Dec 03, 2009 | Texas Instruments TI-83 Plus Calculator
How do i start tomcat server?
I ll share config steps that I use:
1) After installing the Tomcat server set the environment variables in the following way :-
a)var name:path
var value:C:\Java\jdk1.5\bin;C:\Tomcat 5.5\bin
b)var name:classpath
C:\Tomcat 5.5\webapps;C:\Tomcat 5.5\common\lib\servlet-api.jar
c)var name:JAVA_HOME
d)var name:CATALINA_HOME
Var Values:C:\Tomcat 5.5
2)After setting these variables check to see if the server is running by typing "http://localhost:8080/" in the web browser.
3)If you can see the Apache Tomcat page with the message "If you're seeing this page via a web browser, it means you've setup Tomcat successfully. Congratulations!" then everything is fine & server is well configured.
I havent tried it on Win 2000 yet, these steps I use to configure Tomcat on Win XP & Vista, hope this proves to be of some help to you too.
Apr 29, 2009 | Computers & Internet
How to configure AX 150
EMC offers a great documentation site.
Here is it:
http://www.emc.com/microsites/clariion-support/ax150/install.esp?redirect=true
You can select Install and you can create a great customizes doc for installation steps.
Generally you can configure AX150 from a web based interface.
Enter the ip addess of the storage processor and a java application will appears.
You should do the following:
1. Create raid groups
2. Create LUNs on raid group
3. Register the hosts
4. Add hosts and LUNs to a storage groups
Dec 17, 2008 | EMC CLARiiON AX150
MSA 1000
Turn off MSA and cluster, turn on MSA and only one server, you will be able to access the data
Oct 17, 2008 | HP StorageWorks MSA1000 Network Storage...
I canĀ“t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
MSA 30 unplugged HDD
Have you spoken to HP tech Support Team? This one is out side my field of knowledge
May 15, 2007 | HP StorageWorks MSA30 14X 72G U320 15K 1TB...
HP StorageWorks FCA 2384 (302784-B21) Network Adapter Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
