Question about Jenn-Air JS48SEDBDA Stainless Steel Side by Side Refrigerator
This refrig has power to the computer but no power anywere not even inside lights
    Sergeant:
    Champion:
  • 351 Answers
Computer is bab re place it hope this helps
Posted on Oct 08, 2010
The light in the refriderator has no power getting to it and the temp display has no light showing
You have a Whirlpool refrig and it has a bad control board . This board is located behind the refrig , on the left side at the bottom , inside a plastic housing . This housing is held on by 2 screws at the bottom left . Remove the housing and the control board inside . Replace the board and reinstall the housing . It costs about $ 80.00 . When you go to get the part , take the complete model number with you so you get the correct board . This board controls the light for the refrig AND the lights for the control knobs PLUS other parts which work ok relating to the cooling .
Sep 23, 2010 | Refrigerators
Check all circuts nothing is on (model #795.7834), does this refrig do a auto defrost and so do everything stop working even the water dispencer
is the light on on the inside of the machine if not then your machine is not getting power all fridges and freezers have an auto defrost cycle whether they be mechanicaly like the older ones or electronic like todays models defrost has nothing to do with you getting water to your door i dont actually think the power going to the unit is on if it is plz repost or send me a reply
thanks
Jul 13, 2010 | Kenmore Refrigerators
Inside lights not working on frig side, working on freezer side, changed all 3 bulubs
You have a bad control board , located behind the refrig , mounted to the bottom left corner , inside the white plastic box . Also , the temp adjustment light , should be out . This board , is held onto the refrig , by those 2 , 1/4 " screws . It is easily replaceable , and costs about $80.00 .
Dec 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
All the lights in the freezer are working. None of the lights in the refrigerator are working. All the bulbs have been changed. Is there a fuse in the refrigerator that would make the lights go out?
In your model , the refrig section light , gets its' power from the control board . When the lights stop working , so will the light for the temp adjustment display . The control board is located behind the refrig , at the bottom , on the left side , inside a white box . It is held on by 2 screws . The part costs around $ 80.00 , and is easily replaceable .
Nov 24, 2009 | Whirlpool GD5SHAX Side by Side...
Light does not work in refrigator, it's not the blub.
Disconnect the refrigerator from AC Power. Remove the light bulb, get a flashlight and look into the socket the bulb screws into and see if there's any corrosion in the socket that could be preventing power from getting to the bulb. If there is corrosion get some steel wool or a scouring pad and thoroughly polish the inside of the socket, (CAUTION BE SURE THE REFRiGERATOR IS NOT PLUGGED INTO THE WALL AC OUTLET WHILE DOING THIS,) After cleaning the socket re-install the bulb and plug refrigerator back into the wall and see if it lights up,when the door is open, if it doesn't, the next thing to check would be the switch that applies power to the bulb when the refrigerator door is opened. It could be stuck or it may have gone bad.
Sep 04, 2009 | Amana Refrigerators
Good evening, My Maytag refrig/frez s/s model #MSD2756DE is very warm inside. This started after a thunder storm. It's making a clicking sound every 2-3 minutes. It sounds like a compressor wants to start...
Sorry to tell you this, but your compressor is stuck, your chance of getting the compressor unstuck is about 1%. Companies warranty their compressors for 5 years on the average. If the fridge is older than that, it doesn't pay to have someone replace it, it would be time for a new fridge.
Jun 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is making clicking sound and won't run
The relay for the compressor is right on the compressor itself. when you remove the back cover from the refrig there is a bowling ball looking motor. and there are 2-3 wires running into the side either under a cover or to a white looking peice. be sure to disconnect power b-4 removing the relay. once removed shake the relay vigorously and if its bad it will rattle like rocks in a bottle and peices may even fall out. with out a replacement part there is no way to get it going again so you will need to take measures to save your food.
Post the model number off of the refrig (the number inside the refrig compartment usually on the right hand inside wall) and I will get you a part number thanks Peyton
Mar 17, 2009 | Refrigerators
Refrig light out, but lightbulb is new
you dont know how many calls i ran about light buls not turning on and when i get there is loose try giving and extra turn to tighten remove and re install tigh if is not commimnog it might the light switch or loose connection inside.
Oct 31, 2008 | Whirlpool 21.6 cu. ft. Top Freezer...
Ice/water dispenser not working but ice is being made
lighs in the refrig or frezzer not working either???id check your outlet and or circuit braker. at very least yout lights should be on!
Feb 24, 2008 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
