Question about Sony Handycam DCR-TRV103 Digital Camcorder
I recently purchased this from a pawn shop. I tried playing back a few of my old tapes and the video and audio is choppy. Is it the camcorder, settings or tapes?
    Genius:
  • 1,340 Answers
It could be the tapes or the camcorder.If the tapes were recorded at slower speeds than SP,I find that the tapes do not retain the videos as well.Also,if the tapes were stored near a magnetic source such as speakers for a while,that ruins them too.Depending on the age and previous usage of the camcorder,it could be dirty heads.You could try a VCR head cleaner.For settings,I do not know what the options are so I can't answer that.VCR head cleaners should be cheap.I think you get solution with it,clean the middle metal reader with a Q tip,clean the rollers too,spin them with the Q tip itself,insert the VCR head cleaner which is basically a VCR tape with a cleaning cloth wound into it,and run it a minute or 2 or whatever the directions say.That is at least a cheap way to try to make it better.If it doesn't help,you may want to find out if they have a return policy.
Posted on Aug 06, 2010
  • Sony Master
  • 17,130 Answers
It is possible that the camcorder was off use and resulted in drop of values in the servo sections. First of all open the tape door section and do a good cleaning of the audio/control head . See if any dirt had accumulatted onthe heads, be verry careful to clean or use a good quality cleaning tape. Check and see if your old tapes are tight , rewind and forward before playing stored tapes. If this wont solve the choppy playing, thenit is possible that the servo section of the camcorder needs attention. Get help if not familiar as it needs experience to open and probe, but this can also be very expensive. Hope you try the cleaning first. Good day
We can see the image in fast forward or rewind but and no audio
Many parts are still available on these camcorders however if it needs a video head for example, and it's not avaiable it may be a better idea to get another 8mm camcorder off ebay, or maybe a pawn shop. just test them with a new blank tape first before putting your family tapes in.
Jul 21, 2009 | Sony Handycam CCD-TRV308 Camcorder
Video and audio play back is choppy
OK, yes, it probably does relate to a tape tracking problem, but does knowing that help you out at the moment, I had this same problem and I scanned for solutions and somewhere I seen this remedy and it worked, remove the battery and take your open palm and give it a sharp rap at the bottom rear corner, a good solid one but not enough to damage the cam. Hope it works for you.
Jun 21, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Image Sensor Problem
Does the black line record on the tape? When you play back on a TV/Computer can you still see the black line. If you do that would be the image sensor.
Good luck!!
Feb 13, 2009 | JVC GR-D850 Mini DV Camcorder
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Choppy Video
I had same problem. Don't buy a cleaner. Look inside camcorder and make sure both reel turners are equal in height...they can slide down. Turn both of them...one of mine was down and also did not turn to make contact with tape. We got it to turn and the message C31:23 and the dinging quit. Camera instantly worked like it used to. Good luck.
Jan 31, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Playing DV footage that was recorded on a different camera
Canon camcorders have a non-standard head position. Borrow a panasonic or samsung camcorder (those two are compatible) and backup your casettes on dvds. If you want them to be on minidv readable on canon camcorder, connect it afterwards and send video to minidv through your camcorder. It will then be alligned the way that suites your gear.
Either that or go to the professional service that does conversion from minidv tapes. That usually costs around 15$ per hour, so if you have 10 or more hours of video, the less expensive way is buying an entry model of panasonic camcorder.
Jan 03, 2008 | Video Cameras
Playback is choppy
I had this problem very recently. In fact I borrowed camcorders from my friends too and after short periods, they too started having the same problem. Essentially, it looks like there is some choppiness every second or so - like there is noise in the audio and video. After a lot of looking around, I finally found a suggestion posted that ACTUALLY WORKED on all 3 camcorders:
I placed an empty tape in the camcorder and recorded a few seconds into it. Then I removed that tape and tried to play the previous tapes that were showing the choppiness. No problems any more. Everything works fine.
What I still do not understand is why 3 camcorders (all DCR-TRV103s) all showed the same problem (with different tapes by the way). And since I still have lots of tapes to copy, I need to know why this problem is happening so I can minimize its occurrence while I complete the copying process.
People have suggested that my tapes are old and may be offering resistance to the camcorder. So I have ordered a rewinder to spin the tapes a bit before trying again. The two possibilities suggested around this was (1) some mechanical switching took place which got reset when recording; and (2) something got corrupted in the software that manages the playback buffer and that software was rebooted when it went to recording mode.
So while this will hopefully answer your question, I'm also looking for explanations for why this happened to me on 3 different camcorders.
Oct 05, 2007 | Sony Handycam DCR-TRV260 Digital Camcorder
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Mini DVC Tape
Hi Luigi, Have you tried playing the tapes on a different camcoder we would want to start by a process of eleimination.
Apr 20, 2007 | Fuji DVC-M60 Mini DV Tape
Sony Handycam DCR-TRV103 Digital Camcorder Logo
141 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
