Question about Xerox Phaser 3150/B Laser Printer
Orange led blinking - Xerox Phaser 3150/B Laser Printer
Orange led
It is unfortunate that the computer just displays 3 orange and 1 white LEDs. Request you to let me know the system model and then I can check and see what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jun 26, 2014 | Dell Inspiron Computers & Internet
Battery led blinks orange on dell inspiron 5160
if the battery LED blinks orange, most likely there is a problem with the battery itself. Try to remove the battery and have the power cable connected to it. If there is no battery LED blinking, call Dell to replace the battery itself..
Aug 20, 2011 | Dell Inspiron 5160 Notebook
What is error code 6500?
This is an error indicating a problem with the Logic Board Assembly. It's probably not worth fixing, with printer prices being fairly low.\
According to the MP800 Service Manual:
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (COPY button), or
Alarm LED Lit in Orange)
Service call errors are indicated by the number of cycles the Alarm LED and COPY button blink, and the corresponding error
code is displayed on the LCD.
*Cycles of blinking in orange (Alarm LED) and green (COPY button) - 20 times
*Other hardware error - Error
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
Aug 21, 2010 | Canon MP830 All-In-One Printer
LED light keeps blinking
That is a service error code, but you need to count how many blinks between the longer green blink, and that tells the error code...
Oct 13, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
My Acer netbook will only keep an internet connect when plugged in.
This netbook has a little orange led that blinks to let you know that the wireless is turned on. Then you know you can connect to wireless networks. Take a look at the photo here:
www.geekzone.co.nz/images/news/AcerAspireOne.jpg
To the right of the touchpad, at the front edge of the palmrest (closest to you) you will see a small silvery stripe. This is where the wireless led is.
First, look and see that the little orange led is blinking. If not, slide the little switch right beside it to turn on the wireless (you should see 'wireless lan enabled' in large green print) If you can't seem to get the orange led to blink by doing this, check device manager and check that the wireless card is enabled. If it has a red X on it, right-click on it and left click enable.
If the led is blinking, but you still can't connect to wireless, see if you can connect to another wireless access point other than your own.
Let me know if this helps or not :)
Aug 17, 2009 | Acer AOA150-1690 Aspire Notebook
Xerox Phaser 3150/B Laser Printer Logo
211 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
