Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
I have canon sd1300 camera.Camera lens is not going inside when turning off the camera.Showing the message lens error & automatically reset. Any help in solving this issue would be appreciated. Thanks
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Lens error for digital camera,lens error well shutdown automatically restart your camera
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 13, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Hello! I have a canon powershot S1300 IS and when I go to turn my camera on, it says Lens Error Will Shut Down automatically. restart camera. I don't know what to do...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 03, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My canon power shot sd1300 IS is having issues. I turn on the camera and it says "lens error. will shut down automatically. restart camera" how do I fix this problem p.s. i have turned the...
The camera may have suffered an impact to the lens unit or a piece of grit maybe lodged inside of the lens unit. I suggest you take the hose from your vacuum and put it in the front of the lens then turn on your camera. Hopefully the grit maybe dislodged with the suction of the vacuum. If the lens is bent or crooked then try to put some force on the lens to push and straighten; be careful with this because the lens can break very easily.
If this still does not work then you will need to send in for service. The authorized service facility that I use is Photo Tech in NYC. You can visit them at www.phototech.com
Good luck
Paul
Jul 16, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I was taking photos when suddenly my Canon PowerShot SD 1300 IS IXUS 105 read "Lens error. Will shut down automatically. Restart camera." Then the screen went blank. The lens will not retract....
There is something wrong with your lens barrel. It can be anything from some sand/dirt that got inside in which you try using some canned air to blow out the particles while continually turning it on and off. Usually what it is from is the camera being dropped, even if it is in a case or inside a bad. The jostle or direct impact of the fall will break some small gears or tweak the lens off of alignment. If it was from an impact then you lens barrel needs to be replaced and in that case the repair cost are usually as much as getting a new camera. You can send it into Canon and get it repair for a flat rate. Sorry about your camera.
May 25, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My camera is canon ixus 105.i cannot turn it on.the lens is not coming out.its says "lens error will shut down automatically Restart camera".what should i do.?thanks
something has malfunctioned in the lens motor itself, unfortunately this means that your going to have to take the camera into a repair shop or send it back to canon for repair.
May 05, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Lense error camera will shut down automatically reset camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 27, 2010 | Canon PowerShot SD1300 IS IXUS 105...
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
820 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
