Question about Electrical Supplies
Dear sir, I have just purchased an ingersol rand 20 kva generator (2nd hand) it is a 2009 model, (model No G20) almost brand new. The problem is it came without a manual. I contacted a rep fom Doosan (Doosan recently bought Ingersol Rand) in the US he emailed me what he thought was the correct manual it was for a G20 but not the same G20. A plate on the cabinet says it was manufactured in Dublin Ireland, but I am having trouble contacting anyone there. Do you know if there is some way of identifying one G20 model from another.. Would the serial number help? Serial number is G0200428
mamicheddy
  • 79 Answers
SOURCE: IR G7VE Generator Manual
The best place to obtain manuals at a discount price is -
repairmanual.com
Hope this works for you.
Posted on May 09, 2009
ROMOAS
  • 97 Answers
SOURCE: I have a 50KW ingersoll
to break the marriage of the units there should be a screen holes on the gen head remove the screen and look inside there are 2 type of mountings 1 is a rubberized gear looking spline this is a damage for shock loads from the engine they just slide out the other #2 is a flex plate type with bolts to the engine fly wheel you need to remove these bolts you will have to rotate the engine some times to get to them all when this is done at the bottom inside the ger use wood shins between the armature and the commutator the metal parts be careful for to damage the windings some times the access holes have a alignment where you can place a shaft and run under the gen head shaft to support it then unbolt the gen head from the engine bell housing wrap the gen with plastic till a new engine is ready to install hope this helps
Posted on Aug 31, 2010
EMSRSERVICEG
  • 426 Answers
SOURCE: where do i find a
TRY GOOGLE.COM
Posted on Dec 27, 2010
  • 3 Answers
SOURCE: where can I find a oweners manual and spec. sheet
Ingersoll Rand generator business was purchased by Doosan so you could probably email them and ask for the manual. Here is their web site:
http://www.doosanportablepower.com/americas/Pages/home.aspx
Here is the generator info
http://www.doosanportablepower.com/americas/products/generators/Pages/PowerSource%20G80.aspx
good luck
Posted on Mar 06, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I have an Ingersoll Rand
Contact these folks: They should be able to either holp you or tell you where to get your parts.
Central Power Systems & Services
9200 Liberty Drive
Liberty, Missouri 64068-9396
http://www.cpower.com/partsService/parts/partsFinder.aspx
Phone (816) 781-8070
Email: info@cpower.com
Kelly
Posted on Jul 28, 2011
What is the general specification of Genset 20kv?
Generally 20 Kva power generator can produce more power. The voltage used in this 20 kva generator is 3 phase with frequency 50 Hz. 20 kva generator engine is already very enough for use on buildings that require large electrical power or public places such as shops. According to me HARGEN provides the best high quality genset.
To fill the fuel tank to the full required 62 liters of fuel in order to use this 20 kva generator engine with more leverage.
20 kva generator engine is also issued a noise that can reach 61.7 db or can be heard up to a distance of 7 meters away from where this generator is located.
Sep 11, 2017 | Cars & Trucks
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Why our g25 ingersoll rand mobile disel generator when start it cause overspeed and shutdown immediately
Check the mag pickup screwed into the casing where the flywheel is. Check for dirt and metal chips
Oct 06, 2014 | Ingersoll Rand Used Towable G25 21kw...
Nagged@southernphone.com.au
there are a lot of online resources for manuals if you had a spicific model that might help.
Aug 12, 2014 | Electrical Supplies
HOW TO SWITCH 6260 TO 60HZ
6260 isn't a model number for any Ingersoll Rand generator.
Generally, though, if you have a generator that generates 50Hz and you want it to produce 60Hz instead, you adjust the governor to increase engine running speed by 20%... if the engine will tolerate that speed. The first thing you need to do is find out what speed the engine runs when it's under normal load. If that speed can't safely be increased 20%, then the generator head has been built strictly for 50Hz and there's nothing you can do about it except run a UPS between the generator and your load.
If the engine speed IS low enough to safely increase by 20%, then that's what you do.
Jul 03, 2014 | Ingersoll Rand Electrical Supplies
Oil seperator
Get the model and serial number located to the right side of the fuel tank 1/2 way up on the radiator and call someone who deals in Ingersoll rand (now Doosan). If you remove the old one you can read the numbers off the bottom of it.
Aug 29, 2013 | Ingersoll Rand Electrical Supplies
Where can I find a oweners manual and spec. sheet to download for a ingersoll rand g80 generator ?? I am wanting to wire a outside box with several plug on it.. 120v
good luck
Mar 06, 2011 | Electrical Supplies
Where may I purchase or download a complte repair manual for the Ingersoll Rand model # 2475N7.5? Thank you in advance, Gary
I would suggest contacting a local Ingersoll-Rand air center, a lot of times they can make you a copy for little or no charge
Dec 28, 2009 | Ingersoll Rand - Rand Type - 30...
How to reasseble the open compressor model esv 7*5 by own. we dont have repairing manuals.its an second hand purchased compressor
Not what you want to hear, I'm sure, but I'd recommend contacting your local Ingersoll-Rand distributor. These double acting, water cooled machines require substantial expertise.
A unit of this size (probably 20-25HP or so) is probably going to cost more to rebuild than a new screw compressor costs. However, they can be very efficient machines.
Oct 28, 2009 | Ingersoll Rand 2545/7100 Electric Air...
Electrical Supplies Logo
42 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
