Question about Olympus Camedia C-3040 Zoom Digital Camera
I want a list of the likely different faults which can cause an Olympus C-5060Z not to power on. I'll do the rest. A wiring schematic would help too. I am aware of possible cause being the On/off switch under mode dial and how to replace that, and have a new mode-dial/power switch part, but while the camera is open where the switch can be function tested at ribbon cable connection, I need a check-list of the other most likely causes in the order of most likely to least likely. That means anything as simple as a fuse or power supply item. Please don't waste time about obvious dangers working with electronic circuits or factory or other service facilities. I also want the camera internal flash circuit tested while camera open
  • 1 more comment
  • jonbyus Aug 06, 2010
    Somehow this heading came to be about a C-3040 which is in the same class of Olympus C class of cameras, but much older and totally different technology than the C5060 specifically referred to in my question so the schematic would be different as well as the switches, parts etc. I don't know how to correct that other than this comment, so when researching wiring diagrams service manuals etc know that the camera model is Olympus C-5060Z. Thanks.
    When all the firmware, hardware, or whatever-ware trouble-shooting has been completed by the technician (or facility) there will be a determination of what will fix that specific issue on that specific make and model digital camera (not flashlight.) What would be the most likely fix for one make and model might not be very high on the likely causes on another model. For example, one reason the switch is often a cause of power-up failures on that model is due to it's vulnerability to impact because of it's location on the camera not to mention the physical handeling of it by the photographer as opposed to other models like the somewhat newer C-8080Z which has an improved method of powering on and off by the touch of a button.
    I believe most camera repair facilities which would work on that model often would stock certain parts, boards, etc based on their likelihood of needing them which is only one of the reasons I specifically asked for a list of likely causes of the power issue prioritized generally to it's likelhood of happening. I am aware that the factory does not release certain documentation except to facilities of their choice. That is one reason I asked that time not be wasted referring to the factory. More simply put: In wording the question in the way I did from the begining was to not only emphasize the importance of the diagnosis but also the results of the outcome and certainly not to play down the importance of doing it properly. Neither am I asking anyone to fix the camera. If you don't have access to the info, and schematics etc not a big deal, just don't waste your time with info I didn't request or need even if it's allready there. Thanks
    If the camera would try to go through the power up proccess, I would consider that the lens might be stuck and prevent it from completing the power up process. We have another camera like that. It does not turn on at all with a very good and tested battery or with the AC adapter. A source for parts is absolutely not a problem including a lens assembly or circuit boards. Which parts are the most likely to be causing the problem of the camera not attempting to power on. Please refer to first questions. Because of Parts availability not being a problem I think that my proccess of elimination approach to the troubleshooting with positive ideas from your experts is a better choice even if we ultimately, use a facility with all the more sophisticated test equipment. If it turns out to not be cost effective and the camera becomes a parts camera at least I will know with some certainty which parts are good.
  • 3,083 Answers
Here's an excellent blog about dead camera problems:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Aside from severe oxidation on the internal battery contacts, or power switch, there's also the possibility, as you suspect, that the power feed circuit might be bad. Wish I could help you there, but cannot come up with a schematic, and unless you can find a shop that might have one, I doubt you'll get any help from Olympus, due to the item's age. Guess you've called around to the local shops, but that might be a lead, if you haven't tried already.
As far as the flash is concerned, you can charge up the flash capacitor while you're in there, and check it- it and the xenon bulb are the most suspect components to fail in that circuit, aside from the step-up coil, and you can ohm it out, although it still can be shorted unless you know the coils resistance.
I bought a Camedia Polaroid model in 2002, and it still works, however, I get a slightly grayish screen when I power it up. If I give the camera body a solid WHACK with my hand, it works. This, obviously, is a mechanical problem, but I bought a better one, so haven't investigated the problem. Probably not the same problem you're having, but just throwing it in...
I've never seen a fuse in any cameras I disassembled (a few Olympus), but if they have a fuse type component, I would suspect a FL (fusible link). They're usually around 1 ohm, and serve as current overload protection.
I would suspect a device of this type, if any, since the voltage is low, as well as current. There may be none.
Hope you find that schematic- it's tough to trace stuff out without one.
Good luck, hope something here helps...
Posted on Aug 06, 2010
  • jonbyus Aug 07, 2010
    Thanks tbreeze47, Some good points, and I also briefly checked out some of your ideas. My parts diagram shows 3 fuses, but without a schematic they are not much help to me. REF: #5001 part number VC865800 is fuse 32 volts 2 amps Remark PW-1
    #5002 part number VC865900 is fuse 32V 1A " PW-1
    #5003 part number VC 865900 fuse 32V 1A " PW-1 I find no part named capacitor. there is one called battery recharge remark CP 1 part number VC 880300 ref .Z3001
    one called strobe VC799300 remark 3-A1
    " " Fuse VC775400 32V 1.5A remark PW-1
    These also might be parts in the electronic circuits. I would appreciate your thoughts on this. thanks again,
    President:
  • 2,761 Answers
The most common are lens damage, dirt/dust in lens assembly, and battery problems. If you've dropped the camera you may have lens damage that is preventing the camera from completing its power-up sequence. If you frequent beaches/sandy areas or frequently carry your camera in a bag, you may have dust of grit in the zoom assembly that's preventing the camera from completing its power-up sequence. If your batteries are more than a year old they may depleted to the point that they cannot take or hold a charge sufficient for the power-up. You may also have a corrosion buildup on the battery terminals and/or camera contacts that is preventing power flow. Lastly, your charger may be defective. Hope this helps solve your problem.
Bill B
  • 6 more comments
    Thanks Bill B, all good basic starting points to consider if the camera would begin it's power-up sequence, but it doesn't which is one good reason to consider the new on/off switch I allready have with the new mode dial. I am familiar with how to do that but would rather not use it if not neccessary We have another C-5060 Z with a stuck Lens issue which may be as simple fix as the one you describe as the potential problem, but if not, it may be a doner camera for most any other needed and unavailable parts including circuit board parts etc. The battery tests with more than ample voltage and camera will not turn on with it's AC adapter either which works great on other C-5060 cameras. Charger is not a problem but common sense proccess of elimination troubleshooting would certainly use all of your good points.
    Thanks Bill B, all good basic starting points to consider if the camera would begin it's power-up sequence, but it doesn't which is one good reason to consider the new on/off switch I allready have with the new mode dial. I am familiar with how to do that but would rather not use it if not neccessary We have another C-5060 Z with a stuck Lens issue which may be as simple fix as the one you describe as the potential problem, but if not, it may be a doner camera for most any other needed and unavailable parts including circuit board parts etc. The battery tests with more than ample voltage and camera will not turn on with it's AC adapter either which works great on other C-5060 cameras. Charger is not a problem but common sense proccess of elimination troubleshooting would certainly use all of your good points. Thanks,
  • 12,061 Answers
9/10 it is the actual logic microprocessor, or a sensor that fails or the associated memory, that needs to be attended to to effect a remedy.
One needs special software and cables to be able to attempt any type of repair, in reality this is NOT a device that can be repaired by an end user unless they have the specialized, knowledge and the software and hardware testing equipment required. plus the required replacement parts too.
You need to debug the processor, and memory. And perform the Diagnostic testing routines that will isolate the section faulty.
Olympus simply do not and will not release the schematic diagram and or service manual to the general public. Also without said manual, one simply cannot order parts as one has NO parts numbers to ask for them, further Olympus simply again will NOT sell parts to a Non-authorised service place/man.
In fact "They" do NOT repair the boards as such, they simply replace the entire defective section. With a new one drawn from stock.
"Please don't waste time about obvious dangers working with electronic circuits or factory or other service facilities" (sic)
Well as above, you most likely do not wish to hear this, but your time and money would be better spent towards getting it serviced by qualified engineers. I have over 35 years of experience to back up my comments too.
I could indeed, possibly, give you a list of things that may stop this unit from powering up... but the list would be almost endless... I mean come on.. It isn't a flashlight. it is an extremely complex piece of electromechanical engineering. And almost ANY thing, can & will cause it to stop working as it is really a Computer, and as such, it can and does have all & any problems associated with a computer, PLUS hardware issues too, that will stop it working, from software problems to hardware issues.
Anyway that's my 10c worth.
Dual media car stereo won't cut on.. Went out once,but cut right back on now completely off, will resting it help?
Wiring, schematic, electrical diagrams, service info, repair info, removal/ installation, step wise info on everything including error codes/fault codes etc are contents of these online books they sell here on this website www.reliable-store.com
Must check it out
May 27, 2018 | Cars & Trucks
Tip
My Pioneer displays Overload
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
on Jun 22, 2009 | Pioneer VSX-D608 Receiver
Check engine light keeps coming on with different codes i was told it could be in the wirring/?
it could be the wiring but we have to know the codes to help
all codes state in their list of possible causes that wiring-- unit - mechanical and ECM are all possible reasons for the fault
remember engine lights report on the transmission fault as well as engine
Oct 22, 2015 | Cars & Trucks
I need the wiring schematics for 2006 equinox
try this site autozone. they ahve a lot of wiring diagrams. jsut go down the list until you find your diagram.
Repair Guides Wiring Systems 2006 Power Distribution Schematics AutoZone...
Feb 03, 2018 | 2006 Chevrolet Equinox
What amp and volts fuse goes to the radio red wire and the yellow wire on 1986 harley flhtc
I have a schematic for an "89 model and it looks like the red wire takes a 1 amp fuse and the yellow wire takes a 5 amp fuse. I can't be positive about this because the printing is very small and even with a magnifying glass is not very clear. The voltage rating of the fuse makes no difference in such a low voltage system. You can use a 250 volt fuse in a 12 volt system but the other way around. I would send you a picture of the schematic but this forum limits the file size to 150Kb. If you contact me directly at wd4ity@bellsouth.net I'll send you a copy of the schematic, 3 jpg files.
Good Luck
Steve
Jun 19, 2011 | Harley Davidson FLHTC Electra Glide...
The drivers side power window, heated seat and 12v outlet do not work. is it a fuse?
Could be, but do the rest of the windows work? If so, then it could be the switch, since the driver window gets the most use. These items should be separate- unless they all stopped at the same tim- then it could be a wiring issue somewhere. Take off the cover of the fuse box. It is at the end of the driver side dash panel. Open the frivers door, and look at a "D" shaped panel on the end of the dash. A sharp pull will dislodge it. On the BACK side of that panel will be a listing of each fuse on the fuse box. One by one, locate the different fuses that you suspect could be the culprit(s) Take one out, inspect it, replace it if it is good. keep going until either you have exhausted the possibilities, or found the one causing the issue. I cannot find a fuse for the heated seats in my schematics, so I think it may be a relay. Is it only the driver side heated seat? Again, it gets the most use. Check underneath to see if it could be unplugged or loose. And I cannot find a circuit in the schematic for the 12V outlet (cigar lighter in the old parlance) either.
Good luck on this. I hope it helpes. Let us know if any of these things hit on your issue!
Jun 10, 2011 | 2000 Chrysler 300M
Nails were loaded backwards in my Hitachi nail gun. I can't unload them
Sorry to hear, but it happens.....
You'll have to take the magazine apart and disassemble at least as far as the nail got. I'm giving you the webpage from toolpartsdirect.com for the schematic diagram and parts list to help you take everything apart, and of course, put back together again. http://d3cmirsdb60x3h.cloudfront.net/schematics/hitachi/nv83a2.big.pdf
Be sure to check all parts for damage, such as scarring on metal parts that might cause nails to stick later.
This site is a good place to get parts. Very fast delivery!
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
124 spyder 2000, 1980 wiring schematic
Check out faxonautoliterature.com. They list 2 different manuals for your car and it's quite likely that at least one of them will contain the factory wiring diagrams. I've used them before and had excellent service. Hope this helps.
Oct 17, 2010 | Fiat Pininfarina Cars & Trucks
Loose wires inside my t2958 emachine , need a schematic website
Most of the extra wire are for expansion purposes and since most computers have different accessories,a wiring schematic may not help at all.
If you are just talking about the wire from the power supply box,I can help.
May 10, 2009 | E-Machines (T2958) PC Desktop
Mitsubishi WD-62525
What is your problem now ?
What do you require ?
REpost your problem
Jan 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Olympus Camedia C-3040 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
