Question about Seagate Computers & Internet
Hello, I have fitted a new Barracuda 500 GB hard drive and have problems. When loading XP the space available message is only 131 GB and Windows will not load. Regards Richard.
  • 2 more comments
  • richard917 Aug 07, 2010
    The XP CD is readable. When I format the drive windows indicates there is only 131 gig available. Windows starts to load normally and then shuts down and reboots. I have 2 of these seagate drives and they both done the same thing. I bought the second one because I thought the first one was faulty
  • richard917 Aug 08, 2010
    This is a SATA hard drive fitted to a 3.2 gig motherboard which is about a year old. The latest is I made a 20 gig partition on the 131 gig space available (acording to windows) and loaded XP on that which worked. I then used PC Professor to creat 3 partitions and format them on the remainder of the hard drive (446 gig by now with PC professor). Partition sizes were 46,200&200 gig. I now have a unmountable boot volume error. I have tryed the windows repair process with chkdsk and fixdsk without success.
    Sata hard drives do not have jumpers or need to be set as master or slave according to my instructions. I tried starting in safe mode but could not do so. I got a system 32 error flash on the screen and then the unmountable boot volume error.
  • richard917 Aug 11, 2010
    I have appreciated the advice which was provided. The PC is now going again and I don't really know why, a friend loaded a different XP disk on it and it worked, he reckons the problem was that I did not have drivers loaded. That did not sound right to me, as far as I know Windows already has drivers for most things.
    President:
  • 2,030 Answers
The bios in your system can not handle a drive larger than 256MB...you will have to either update the bios (may have to pay for a newer one), or get a smaller drive....or a new computer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 08, 2010
  • 4,281 Answers
First make sure your harddrive set as master . For that you need to check the jumper in the back of harddrive. There is instruction hoe to set it as master. Also make sure both connection connected to harddrive are working fine. Also when you power up the computer press F8 key then you can see safe mode and other menu enter in safe mode. Then go to start menu->run type in run "chkdsk /r" without "" then press enter then press "y" then restart computer then it will fix and recover errors on harddrive. Let me know if you need further assistance. Thanks for using FixYa.
  • Change the SATA cable connect it to different SATA ports.
    Then when you power up the computer press F1 or F2 or del or ALt+F2 to enter in bios.
    Then load optimal defaults settings save settings and exit.
    Then check.
  • 1,675 Answers
Hi richard
some older pc will only recognise a certain amount of hard drive space, you might have to partition it to recognise 2 drives instead of one, if your pc is newer than this, the best way to do this will be to run the drive alongside your old drive as a slave, and use windows to partition it as required, normally when you set windows up, on a new drive it has to be formatted first, i don't know if you get to the stage where you can do this in your windows set up, also, just a question, i gather this is a SATA hard drive? this is another problem i have come across, windows xp does not recognise these drives, they will only recognise IDE type, this sounds more the problem than the first idea, there is a way you can do this it is somewhat long winded, but i have given you a link to read it will explain all the ins and outs of doing this, hope this helps you
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
click on link above
Posted on Aug 07, 2010
  • steve morris
    steve morris Aug 08, 2010
    once windows has installed have you tried going to, the control panel, then administrative tools, then computer management, then look for disk management, this will have tools for you to use to enable windows to read all of the hard drive, or partition it and set active partitions...hope this helps
  • steve morris
    steve morris Aug 30, 2010
    wow look at that my answer was same if not more involved than the 4 thumbs and you reject? and only give me 2 thumbs? cheers for that
    Genius:
  • 1,478 Answers
Verify either in the system you are using or another computer that the CD is readable. It's possible that the CD is bad/corrupt or not readable. In this case, get another copy of the window xp operating system. But if the CD was able to boot from another system, first try format the hard drive before you now install the windows on it.
Take care.
Posted on Aug 06, 2010
Describe your Seagate Barracuda 7200.12 500 GB SATA Hard Drive is not getting detected in BIOS
It requires special hard ware tools to solve this problem. they are available with me and it just takes 20 minutes to get your data back. this is called LBA ZERO REPAIR, AND TRANSLATOR REGENERATION.
Nov 22, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
The Seagate Barracuda 7200.10 500 GB SATA Hard Drive External falled and now is not more recognized by my pc Win XP
Hello
OK, you need to let me know if the drive spins up, you should be able to hear it. Also, you need to have a listen if the drive makes a clicking noise.
Please be so kind tom let me know.
If the drive makes a clicking noise the drive is done, you will need to take it to a recovery institution to recover the data.
If the drive does not spin up, the circuit board or the power cable might be broken.
Hope this can be of help.
Kind regards
Andrea
Jun 17, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My brand new seagate hard drive is showing on 120 gb space on partition time?
it means your hard disk have 120 gb capacity, you can make partition according to your requirement.
Apr 02, 2010 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Using windows xp but want install windows 2007
the message might be either about your hard disk or mostly about your RAM size. for windows 2007 these are the basic requirements
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
    if your system does'nt meet the req then upgrade it and then install the operating system
Aug 29, 2009 | Microsoft Windows XP Home Edition
I cannot install windows xp sp2 on my seagate barracuda 72000.10 500gb hard drive
I would suggest you go to the seagate website and download and burn out their hard drive test. run the test from boot and see if it detects a bad hard drive after it runs
Jul 11, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Gowthaman
Check if the jumpers on the hard disks are in the right position.
Apr 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computers & Internet Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
