Question about Hoshizaki F-1001M Flake Ice Maker
Grinding vibrating moaning sounds when augur engages ice. no noise without compressor running
    Director Badge:
    Uploaded 100 video answers.
  • Hoshizaki Master
  • 489 Answers
This machine had same issue. I replaced gear box. Oil leaked out.
Posted on Jun 09, 2016
    Novelist:
  • 112 Answers
Three possibilities - 1. bad auger or auger bearings 2. dirty evaporator barrel (calcium or sediment buildup) or 3. water float sticking or water flow stopping for some reason and not keeping the evaporator filling with water. I would start looking in reverse order from 3 to 1.
Posted on Feb 02, 2015
3 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Automatic Ice Maker making grinding noise and will not release ice
The mold heater on the bottom of the ice maker is shot, that is why the cubes will not release. The grinding is the sweep arm trying to push the frozen cubes out.
Posted on May 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: ice maker making a grinding noise. I remember a
Yes - if the noise does not stop - please re-post.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 29, 2009
What is causing Scotsman icemaker to moan
perhaps it's unhappy? I can't say i blame it, if I had to sit there all day in the freezing cold making ice I would moan too.
here's a list of possible problems
If it makes excessive noise:-
Problem and Likely Causes/ Probable Solutions
Fan blade vibrates Blade is bent Replace fan blade
Fan motor mount is broken Replace motor mount
Compressor vibrates Mounting loose Check mounting
Water pump vibrates Pump bearings worn Replace pump
Panels vibrate Mounting screws loose Tighten screws
and ice can groan as it expands, but that only applies to large icebergs
May 14, 2014 | Scotsman Freezers
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Poulan riding mower grinding noise
Sounds like bad gears in transmission.
Sep 07, 2017 | Garden
Chevy Aveo grinding noise from accelerator when A/C is on
It will be the ac compressor clutch that slipping when after it has been activated/engaged. This happens when the engine is winding up the compressor clutch is not engaging strong enough and start slipping. However as the engine rpm stabilize on the ac compressor has caught up (same rpm) no slipping occur and no noise. Was the clutch mechanism replaced with the compressor replacement? (however it need to be checked/repaired).
May 08, 2017 | 2009 Chevrolet Aveo
Noise from rear of unit like bearings grinding ie motor noise etc.
There should be no moving parts on the back. Remove the lower panel and lay down with a flashlight. The compressor may be located toward the rear, on the bottom. It looks like a cylinder with piping coming off it, and reaching to what looks like a mini car radiator. This is the coil.
Only moving parts are a fan for the coil and the compressor. See anything out of the ordinary?
Replacing a fan is easy. A failed compressor may be the kiss of death. If the noise is coming from the compressor/motor, call a local technician and ask how much to change it out. Warrantee?
good luck Spencer
Oct 07, 2010 | Samsung Refrigerators
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
Moaning noise reversing while turning wheel to left
The moan is caused by the brakes and the vibration is due to a defective part on the front end a tie rod end or drag link. If you want more information I would be glad to assist but have to run to work so post here and I will give it a shot tonight when I get home.
Sep 30, 2009 | 1995 Lincoln Continental
Turbine/moaning sound and vibration
The grinding sound that you are hearing is your color wheel. They can make a noise from a buzz to a power saw type of noise. Usually the set will continue to play with the noise, but it is annoying. You will need to replace the color wheel now.
This is not as easy as the lamp replacement, as you have to pull the light engine to access the color wheel. It is not hard just more work and be careful of the color wheel lenses.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 03, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Moaning noise when I turn left or right in my 2002 VW Passat
Your power steering pump has gone bad. Consider replacing it. I had the same problem before.
It moans when u turn at a stand still but rolls freely when in motion?
Rate this fixya
Mar 24, 2009 | 2002 Volkswagen Passat
Condensor sounds like it moans for a couple of seconds instead
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Dec 03, 2008 | Refrigerators
Hoshizaki F-1001M Flake Ice Maker Logo
678 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Marvin
Marvin
Mike Squire
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
