Question about Canon iR 2020i Laser Printer
When making two sided copy, a messae is given like "Remove doc. on glass"
  • 1,219 Answers
please be specific, did you put original in dadf ( auto feeder ) or on copy glass?
Posted on Aug 06, 2010
How do i stop my sharp mx 4111n printer from printing with line on the paper
does this happen when printing? or copying? if printing check the fuser, image /drum unit What color is the line replace that image unit, if copying does it happen thru the doc feeder ? if so place on the big glass and make a copy if it goes away the its the doc feeder slit glass that is small glass use by the doc feeder, big glass not used by the doc feeder when copying or scanning
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 17, 2015 | Sharp Office Equipment & Supplies
I have a sharp ar-bc 260 have perfect black lines on copies only copy mode print mode is fine
Clean all your glass including the thin strip on the left side that handles scanning for the doc feeder. Run copies both off the glass and the doc feeder. If the line is still there then take off the glass, dust the inside scan cavity and dust your 3 mirrors with a new, lint free rag. Make sure your glass is completely clean before you put it back on.
Jan 17, 2011 | Sharp AR-BC320 All-In-One Led Printer
Copy is a black line
If copying from doc feeder the glass may be dirty. Run a copy on the glass if no line then clean the doc feeder glass.
Aug 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How do you make two-sided copies?
Afraid this is a "Simplex" machine. To make duplex copies you will have to put paper back in cassette to copy onto second side, and then turn original over on glass or into doc feeder.
May 24, 2010 | Muratec - MFX-1300 Copier
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
I'm getting lines across all copies I insert via the feed
Yep. remove and clean that small strip of glass on the left side of the machine. open the feeder, there are 2 phillips screws, that glass either has somthing on the top or bottom surface.
It makes it easire to clean when you remove it and place it on a white sheet of paper, that way even if it is a really small spot you can see it easier.
The lamp does not move when you use the doc feeder and a small spot on that glass will make line across the entire page.
Jan 27, 2009 | Xerox WorkCentre M20i All-In-One Laser...
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Copies have black lines on them after i replaced the toner
does the lines come when doing copies in the doc feeder only? or on the glass also?
if only in the doc feeder lift up doc feeder and clean the small strip of glass
Oct 30, 2008 | Sharp AL 1631 Copier
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Gray background on all copies
When you tried adjusting the manual adjustment to lighter did it improve? If so, you may just have to clean the optics of the copier. It is easy to do. If you want to try it? Do you have a doc feeder? Turn the copier "off" and "unplug" it from the wall. Next open the doc feeder or cover for the copyboard glass. On the left side of the copyboard glass where you line up your orginals to the sive scale. There are " 2 " small #2 phil. size screws that hold it on " most of the time silver. Unscrew the 2 of them and left up the scale plate, CAREFULLY if you have a doc feeder there will be 1 or 2 spings there. Remove the spring and the copyboard glass. Next move the optics/ mirrors SLOWLY to the RIGHT side of the copier and with a dry and clean rag wipe the 3 mirrors of dirt CAREFULLY. Once you are satified they are clean return the copyboard glass and the 2 springs if remomed and return the scale and 2 screws. Then plug the copier back in and turn " on" the optics will go back to the Right postion by themself. Next make a copy and if it better you are done, if not you may need a new OPC drum & cln blade & a developer change to solve any C.Q. problem. Call a service company at that point.
Jan 26, 2008 | Minolta EP1083 CS/PRO Copier
Canon iR 2020i Laser Printer Logo
53 people viewed this question
old marine
old marine
