Question about SanDisk Sansa e250 MP3 Player
When i turn on it´s show sandisk logo and restart
  • kakima Aug 06, 2010
    Hold down the power button for fifteen seconds. Does that do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Having gone over a month with no response, I assume the reset solved the problem.
Posted on Sep 19, 2010
When i turn on my sansa e260 and show the sandisk logo, it restart showing the logo over and over without going to the main menu, how do i fix it ?
Hi, welcome to fixya!
You need to reset your sansa for it to be in order again.
Learn how to reset the your various San Disk models;
Resetting a Sansa Fuze+, Clip+, c200, e200, or e200R player:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Resetting a Sansa Express player:
NOTE: The device can be either ON of OFF.
1. Press-and-hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
2. Release the buttons.
If resetting doesn't solve the problem, please let me know for more assistance.
Good luck.
Nov 03, 2011 | SanDisk Sansa e260 MP3 Player
Me screen will not function, it is visible on the phone, but is locked up and none of the touch features work. When I slide to unlock, nothing happens. I am receiving phone calls and texts but cannot...
Your phone is frozen, you need to hold the power and the home button together for at least 20 seconds. The phone it´s going to reset then it´s going to show the apple logo and then turn off. Then press the power button for 3 seconds and wait for the phone to restart.
Feb 19, 2011 | Apple iPhone Smartphone
Hi, i have here a Sandisk c240 mp3 player. The prob is when you turn it on, only the logo of sandisk appears and it don't work anymore. Even if you press any keys, only the logo is visible. I think...
only the logo of sandisk appears and it don\'t work anymore. Even if you press any keys, only the logo is visible.I think it needs to be reformat or something.Kindly help please
Oct 19, 2010 | SanDisk Sansa c240 MP3 Player
Sandisk Sansa View 16GB Won't Start
if it is detected in your system,use sansa updater to upgrade the firmware.You will find it here
If not, first download the firmware from here 1.Turn on the View
2.Put the device in Hold (move Hold button until orange is showing)
3.Press and hold the Left Button
4.Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
5.Wait for View drive(s) to mount
6.Extract the downloaded zip file and transfer all the contents to the mounted drive.
7.Disconnect the Sansa View and let it restart. 8.Upon completion of the firmware upgrade, the device will restart. If the restart does not initiate or complete, press & hold the Power switch for 8 seconds to reset the device and then release and press again to restart.
Sep 03, 2009 | SanDisk Sansa e250 MP3 Player
Froze on reboot
if just shows the nokia logo the phone haven´t booted. must send it to nokia repair or find someone with a box to reinstall new firmware
May 26, 2009 | Nokia N70 Smartphone
Sandisk Sansa goes to blank screen. No display and not working
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 26, 2008 | SanDisk Sansa e250 MP3 Player
It shows Sandisk logo and freezes there
Remove the SD card and try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Gray Screen
I had a very similar problem where my Sansa would turn on show the initial logo then fade to a white/grey screen and restart. To fix it started in recovery mode (Start in hold mode with rec button held down) then used the firmware updater to update the software and it seems to had fixed the problem hope this also works for you
Jun 01, 2007 | SanDisk Sansa e250 MP3 Player
When turning on screen fades away then restarts automatically
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
