Question about IBM (25P3294) Motherboard
Nothing can be seen on the monitor, I took it all apart to clean, yes, even the CPU, i accidentally bent one of the pegs, but I bent it back, so it fit in the holder right. I am pretty sure that I plugged in everything else right, but nothing happens when I try to test it on my monitor. HELP!!
  • Ryan
    Ryan Aug 06, 2010
    Does it beep? Any lights?
    Scholar:
  • 55 Answers
Monitor not seeing anything is one of many things. Overclocking is one. if youve overclocked(or just to be safe), remove the battery on your motherboard and place it back in after 30 seconds to reset the BIOS, see if that works. if not, check your video card. if its onboard video, its probably now broken and you need an offboard video card to work. Pins on CPUs get bent all the time, this isnt the problem as long as you didnt physically break it off. Check the monitor on another PC. Hope this helps
Posted on Aug 06, 2010
How do I reinstall the harness for my 2004 Peg Perego P3 Stroller?
Hi Fran
The best people to ask would be Peg Perego - perhaps if they did not fully understand what you were asking sending them a photo would help demonstrate the issue encountered?
Peg Perego Official Website Italia Toys Contact Us
Sep 12, 2014 | Peg Perego PLIKO Baby Gear
How can u tell your motherborad is bad
Disconnect the power cord form the power supply, be sure the power supply is set for 110 or 220 volts depending on your location and power and double check it (most have a 110/220 switch) Feel/look at the back of the power supply to determine if the fan is working. http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm If the fan is working, try another power supply anyway. Plug the computer directly into a known-good (a lamp works) power outlet Check to be sure you do not have a motherboard stand-off in the wrong position and shorting-out the bottom of the motherboard. Inspect/shake and listen for loose metallic objects (loose screws) on top of and under the motherboard and in expansion board slots. Look carefully at the ISA and PCI slots, see if any of the contacts got bent/shorted-out. Sometimes an expansion board will dislodge one and it will be pushed into the bottom of the slot. Inspect the motherboard for broken or burnt components. Carefully inspect the motherboard for black soot from bad bearings and clean and replace the culprit. Look for bent/shorted pins on the motherboard headers and straighten. Be sure the speaker is plugged into the motherboard. If you hear beeps. Decode the beep code. If not, double-check all jumpers. Push down on all chips that have sockets in attempt to reseat them. What CPU are you using? Be sure the core voltage is correct. Be sure the CMOS battery jumper is in the correct position. Some distributors purposely ship motherboards with the jumper in the wrong position. Find the jumper that clears the CMOS, put it into the clear position for several minutes, put it back in the normal position, plug-in the power cord, and push the power-on button. If you apply power to the motherboard with the jumper in the clear position you may damage the motherboard. Pull all boards except video. Disconnect all cables going to all drives, pull all cables except power, power on, and speaker, connect the power supply to the motherboard (the black wires go in the middle on AT power supply connectors--"Black OK, red your dead"), reseat the memory, plug-in and screw-down the display adapter and nothing else (push down on the top, front of the adapter and make sure it is properly seated by looking at it all along the PCI or AGP connector), connect the power-on switch and the speaker. Check the monitor plug for bent or pushed-in pins, connect the monitor and nothing else. Check the monitor power cable. Reseat/replace the memory. Check for Motherboard Electrolytic Capacitor Failures Check the CPU for bent pins. Try another processor. Note: If you apply power to a motherboard with an Athlon or Duron processor without the CPU fan connected, even for a few seconds, you will fry it (see http://duxcw.com/digest/guides/cpu/socketa/heattip.html). Check the CMOS battery with a multi-meter. Should be around 3 volts (2.8 is ok). Try a different video board. See if the CPU and memory will work with another motherboard. Pull the motherboard, set it on the box it came in, install video, memory, CPU, power, and power on. See if it boots. I have seen several instances where this works when the board will not work in the case. And, when reinstalled in the case, it continues to work. I have also seen where it didn't work out of the case immediately, but did work the next day and continued to work. One of those mysteries. Temperamental computers with minds of there own. Replace the motherboard.
Apr 20, 2013 | Computers & Internet
Monitor not display anything and it lighs just keep blinking
Try re-seating the video cable. Try another monitor on this computer if you have one available. Try this monitor on another computer. That will narrow down where the problem lies. It's either the video card or the monitor which is bad. Of course if either is under warranty you may get a replacement, if not get your credit card ready :-) Good luck to you! =============== I would also look at the cable connection and see if there are any bent pins. This has caused issues for me in the past. Just be careful rebending the pins if any are bent. They are fragile and may snap off.
Jan 03, 2013 | Computers & Internet
Fix my motherboard mbp 4xd
If you hear beeps.
See if it boots.
hope this helps
Oct 15, 2012 | Biostar I945P-A7 INTEL 945P CHIPSET SERIAL...
After cleverly spilling a drink into my Vaio PCG-V505ECP I took it apart to clean it. All was going well until I was putting it back together and accidentally pulled the small ribbon cable from the start...
HI This is Neo . find the head of the ribbon ,see that the copper plating is seen . if you see that you will find white head where you can put the ribbon cable . softly try to pull the white part and put the ribbon through the white head and push it and it is done . OR Copper plating is not seen on either side, you have to replace the ribbon . ask some technician to replace it he will do it .
Nov 02, 2010 | Sony VAIO PCG-V505EC Notebook
P4I45GV R5 Motherboard: i have intel 945g motherboard the cpu fan runs but...
Check you Ram. If possible, try with another working ram. Clean the port. It is also possible that your cpu is overclocked, remove the bios battery and leave it outside for few minute and reinsert it and boot the system. If this doesn't helps, you'll need to check your display card also. Try the monitor on another pc. Still here to assist you further. good luck and thanks for using FixYa.
May 16, 2010 | Asrock P4I45GV R5 Motherboard
Problem with VAIO PCV-RS320
The broken pins are definately the problem. Any CPU needs all the pins to work properly. This problem is solved by replacing the cpu.
Aug 11, 2009 | Sony VAIO PCV-RS412 PC Desktop
Rplaced power unit now the monitor will not come up with anything on it. Orange light blinking on front of cpu.
Make sure your monitor is connected to the proper video connection- that is if you have a video card in your machine and a video connection on your motherboard. If you connected to the motherboard and you have a video card -your screen will show nothing even though you are powered up. Dont know your situation, but just checking. Ive seen others do this.
Char S.
May 20, 2009 | Sony VAIO VGC-RB53 PC Desktop
I have a blank screen
so are you asking if there something wrong with your mobo?
if yes, try checking for the jumpers.
Jan 14, 2008 | ASUS P5N32-SLI Deluxe Motherboard
Cpu /monitor
Hi, Sounds like video card problem. Try removing, cleaning the gold contacts and re-installing to the slot. If your PC uses an on-board video that shares with the memory, then you have to remove your memory and clean the gold contacts then re-insert back and try again. If cleaning, re-inserting/re-seating does not solve the problem, then perhaps replacement is required. Hope this be of some help/idea. post back how things turned up or should you need further information. good luck and kind regards.
Oct 01, 2007 | Maxtor Hard Drive
IBM (25P3294) Motherboard Logo
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
