Question about Behringer Pmp3000 16 Channel Audio Mixer
How do I turn on my europower pmp 2000 - Behringer Pmp3000 16 Channel Audio Mixer
  • 5 Answers
The power button (push) is in the back, just next to where you plug power cord.
Posted on Apr 28, 2011
If possible can i get schematic for Europower pmp 980S ?
Request the schematic diagram directly from Europower.
Mar 10, 2018 | Music
Where are the main speaker cables connected to in a behinger europower pmp 2000 mixer amp
The Behringer PMP2000 uses Speakon jacks on the speaker cables. The outputs are located on the back panel. Which ones you use is determined by how you configure the mixer. The Main inputs are located on the right side of the face of the mixer.
Dec 31, 2014 | AMP Music
I have my pc hooked via 1/8" to 1/4' to my europower pmp518m and my sound is very low, but my mics are very loud (need music loud also)
The 1/8 jackon the PC is Stereo so you would need a stereo splitter to then go into separate jacks or maybe tape input on the PMP. Plugging in a mono jack shorts out one side of the PC audio out. Make sure you use a splitter type and NOT a 1/8 to 1/4 stereo cable. It must split into TWO cablles to plug into the PMP.
Mar 12, 2013 | Music
Hi! I need a SM of my europower pmp 2000
This site for the PMH2000 should be near identicla to your unit:
http://elektrotanya.com/behringer_pmh2000.pdf/download.html
Scroll down to "get manual" and click to download schematic. IGNORE other download links.
The HCA2400 amp module in this has a chronic failure and is hard to work on.
Aug 28, 2011 | Behringer Pmp2000 Europower 800w 10ch...
One side of my europower pmp 5000 is out, the other is fine.....what up?
What is up is one of the two power amps is blown... I know this problem... It is USUALLY the rearmost channel which goes to the left Speakon faacing the back. Weak insulation between layers of the multilayer circuit board arcs and fries three transistors and a diode and sometimes a few more components. It takes a lot of skill to restore the module and is beyond most repair shops. A whole new module costs about $155 from Full Compass. The amp is an HCA2400 module, but you MAY need the Behringer part number to order it from Full Compass. Also please read my tip on Fixya for PMP mixers regarding the hazard when using 1/4 inch plugs from the Speakon connectors... the Channel A sleeve is the "hot", not the tip and if you ground the sleeve, goodbye channel A...
Aug 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
My mixer stopped working out of the blue no power want turn on anything ??????????????
Power supply probably failed. This is not a DIY for the inexperienced.
This will be close to your schematic: http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Jul 19, 2011 | Behringer Europower Pmp1000 Powered Mixer...
I need the diagram of behringer europower pmh1000
Here:
Scroll down to "get manual" and click on it to download. Ignore other download links for viewers on the page.
Jul 12, 2011 | Behringer Europower Pmp1000 Powered Mixer...
No amp output.amplifier damage
You will have to have it repaired. Also read my tip regarduing the PMP mixer/amps that if you use 1/4 inch cable plugs to speakers, the SLEEVE of channel A is hot, not the tip. It the sleeve shportss to somehing that is ground, goodbye Channel A or more. This is not in the book.
Feb 19, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Behringer Pmp3000 16 Channel Audio Mixer Logo
186 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
