Question about IBM Infoprint 1532 Laser Printer
Problem 929.00 Service Toner Sensor - IBM Infoprint 1532 Laser Printer
What's E00025-2c0
Error in Cover Sensor (PS14) in M Toner Container
Description Unable to detect opening of the Toner Container Inner
Cover when removing the Toner Container.
Remedy Identify the cause of the error whether it is due to link
mechanism to open the Toner Container Inner Cover or
problem at the Toner Container Inner Cover Sensor side. ?
1. Perform the user mode (Adjustment/Maintenance>
Replace Specified Toner) to check if the Toner Container
Inner Cover opens normally (damage, slide of shaft area,
etc.). ?
2. Check if the Toner Container Inner Cover Sensor is
soiled and the installation of the sensor. ?
3. Check the service mode (COPIER> I/O> DCON> P024
bit9) to see that the output value of the Toner Container
Inner Cover Sensor is changed normally when opening/
closing the Toner Container Inner Cover. ?
If it is normal, the value becomes 0 by rotating the Set-on
Drive Shaft with the attached tool and opening the Toner
Container Inner Cover. When closing the Toner Container
Inner Cover by hand, it becomes 1. ?
3-1. When the Toner Container Inner Cover is not opened
although the Set-on Drive Shaft rotates, check the drive
system from upstream (Set-on Drive Unit -> Hopper Unit
-> Bottle Base Unit -> Toner Container Inner Cover Unit). ?
If it is damaged, replace the damaged part and then
perform step 5 and later steps. ?
3-2. When the output value is not changed normally
although the Toner Container Inner Cover can be opened/
closed, check the Sensor Harness (to see if the harness
is caught, disconnected or physically removed, *including
the Relay Connector). ?
If there is no problem, replace the sensor. After checking
the output value in step 3, perform step 5 and later steps. ?
4. If the problem is not solved by replacing the foregoing
parts, replace the Drum Driver PCB (UN4) and then
5. Clear the error in service mode (COPIER>
FUNCTION> CLEAR> ERR), and then turn OFF and then
ON the main power. ?
6. Replace the toner (reinstall the removed Toner
Container) at least once in user mode (Adjustment/
Maintenance> Replace Specified Toner), and check that
toner replacement can be performed normally.
Sep 24, 2014 | Canon imageRUNNER ADVANCE C5051
Code cof32 appears
cof32 is telling us that ATDC sensor is reading toner supply incorrectly, now this Toner Density Control sensor sits inside the developer unit of this machine, and toner is feed into it, where the atdc sensor reads the amount of toner that it has mixed with the developer and adjust it occording to level initally set when developer was first installed.
Developer can become old and not attract the toner any more
Toner can clog up and not be able to get to it
Developer can be spilt so it is no longer at right level.
Maybe it wont stir cause of something mechanical
Sensor rarely fails
or maybe the ATDC sensor needs to reset it's level (service f8)
not sure but ...Service mode stop 00 stop 01 then select F and 8
link to new dev
http://supplydepot.com/amazing/itemdesc.asp?ic=MIN8936416&eq=&Tp
Nov 05, 2007 | Minolta Di152 Laser Printer
How to clean error 000024-01 in canon 2270
E024-0001 Error Code:
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
However, re-attachment of the sensor also solves the symptom.
When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
May 18, 2014 | Canon ImageRunner 2270 | IR2270 |
E000024-0001 ir4570
Sep 24, 2013 | Canon Office Equipment & Supplies
E000024 0001
I sugest getting the service manual it will help you and u will save money, you can download it from the below link:
http://goo.gl/RLoJzC
good luck
Sep 13, 2013 | Canon imageRUNNER C3200 Copier
Error E00024-01
this error stands for toner sensor fault or disconnected connector on toner assy or on dc controller.
You need to check the sensor on toner hopper, on toner station and on dc controller. after reconnection of mentioned things, if the error is still there you need to replace the toner detection sensor on toner/developing assy.
Hope that helps!
For service manual, if you gonna to try and fix it by yourself, you can write me on emma.servis@gmail.com.
Apr 29, 2011 | Canon imageRUNNER 4570 Copier
Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Jun 30, 2010 | Canon Office Equipment & Supplies
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
Entry into service mode
I need to Know what you mean by purge you toner, The Service mode is use for trained tachnical reps only and if you have had access to this mode you could do more harm than good. the toner ager system of this machine will through a SC592 code if you turn on the Coil and drive to move toner through it unless you kow what you are doing.So a little more info may help me help you.
Jun 03, 2009 | Ricoh Aficio 1085 Laser Printer
IBM Infoprint 1532 Laser Printer Logo
226 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
