Question about Dishwashers
Replaced motor and now is leaking from the gasket, not sure how to make it fit, please help as soon as you can if you can. Desperate.Thank you
  • 12,061 Answers
Use some sort of silicone sealastic sealant around the seal this should help, either that or make an new gasket, and make double thickness and compress well when fitting..
Posted on Aug 06, 2010
2006 subaru forester burning oil
never-- I repeat never --use a used car dealer to do repairs on your car
The people employed are seldom qualified mechanics and they only know how to "bodgie" jobs just to get the car ready for a sale
oil will not leak from a head if the engine is running well , but oil will leak from faulty rocker cover gaskets
from your description, I suspect that when the car went in for the head gaskets a clapped out motor was fitted instead ( check engine numbers on the papers )
If you need a motor , there are plenty of good engines from japanese
engine importers
But at best do not have anything to do with that shop as the engine rebuild could be changing the engine back for your original motor
Mar 11, 2017 | 2006 Subaru Forester
I have a craftsman 17.5 hp tractor that will start but soon cuts off. I have replaced gas. battery fuel filter and spark plug. Also burning a lot of oil to me.Have replaced fuel lines also. Seems to not...
Could be a head gasket. I'd recommend a compression test or better yet a leak down test that will show where the leak is. Hope this helps. Please vote yes, thank you
Nov 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
Slug in my oil,coolant is going down but no external leaks.
Hello coreycose836: My ame is Roger and I will help you. The problem very well could be the intake gasket. And no you do not need to remove the distributor to perform this task. I would recommend you use the new improved gasket set though. The original gasket is made of plastic. The new improved gasket is metal. Cost is higher but it is more durable gasket and less repeat replacement. Be sure to use new coolant and be sure to change the oil. I would recommend doing a oil change in one or two hundred miles do to the sludge build up in the motor. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
Apr 20, 2010 | 2000 GMC Sonoma Extended Cab
How can I minimise the smell of my macerator
Possible causes and solutions:
  1. Poor Ventilation, make sure macerator is properly vent. From top of lid there is a separate 1 1/2" ventilation pipe make sure it's installed and pipe/fittings are undamaged, fittings are all tight and secure. Vent is free of debris.
  2. Leaking Seals. Inspect lid Gasket for damage and deterioration, Replace with new gasket if damaged or deteriorated.
  3. Check all connection to ensure tightness, Lid tightly, Pan Gasket, hose/pipe fittings tight and secure.
I hope this helps in solving your problem, please rate the helpfulness of the answer. Good Luck and have a great week. Jeff
Mar 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Why my 2006 chyrsler leaks tranmission fluid
There are two possibilities
Either a bad gasket or the fluid internal pressure is too high due to bubbles getting in formed. if its gasket problem then the gasket needs to be checked.but if its high fluid pressure then bleeding the old fluid and refilling the new fluid properly will solve the problem. Also check How bad it is leaking? You certainly don't want to run a car with low transmission fluid as it will surely do internal damage. Most common leak areas are at the pan gasket or the transmission cooler lines that go to the radiator. Next most common areas are at the output shaft seals and around sensors or plugs on the transmission. If you replace any cooler lines with hose, make sure you use transmission hose. This will handle the pressure and the chemical resistance that other hoses will not stand up to. Also be sure to KNOW what transmisson fluid is needed. One size does not fit all! This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | 2007 Chrysler 300 AWD Sedan
The coolant is leaking from my cadillac escalade 2002 do u know why
It could be your water pump gasket or thermastate gasket. Have you had any one of them parts replaced recently? They could have put the gaskets on slightly off center causeing it to leak. Find where the leak is coming from. Sometimes the gaskets if old do leak. And if you drive make sure you to watch the temperture gage. Shut off if it gets to hot or you could do damage to your motor. Good luck!
Also if its a slow leak you can put water in it if you not going to get it replaced right away. But make sure to use anti freeze if you think its going to get below 32 degrees soon. Because just water will freeze but for warm weather its a quick fix until you can get it to the mechanic.
Sep 15, 2009 | 2002 Cadillac Escalade
Oil leak on accord
I would replace the filter and oil again ,and lube the filter gasket with motor oil (clean) make sure the old gasket didnt stick to the block,I hope this help you and thank you
Sep 11, 2009 | 1996 Honda Accord
Leaking water from the bottom
take the back cover of ,first check if all the water hoses are tighten,if all tighen then its leaken around the motor area might need a new motor or gasket ,check it when its running so u knw where exactly the leak is,for more info let me know,if my info was of any help to you please leave a comment,thank you.
Sep 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
