Question about Logitech Webcam
I can't get logitech webcam c120m to work on Mini Mac. I plug it into the usb port and it worked for like 5 seconds and I cant get it to work again.
I think this camera work only on Windows, not on a Mac OS, I do not know of any extra driver that can be used, Did you find any?
Posted on Oct 15, 2010
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
How do I find the installation download for the logitech webcam C120m, I lost my CD software I have the webcam and mic that came with it but no CD
All their cameras and software are listed here.
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/3428
Logitech's Support site doesn't list the C120m camera for some odd reason (have had the same problem myself), but the matrix in the link above shows you which cameras use which software, and has links to download each.
Oct 04, 2010 | Logitech QuickCam Communicate Deluxe...
I just installed my Logitech Webcam C120m and it has white lines all over the picture. I reinstalled everything and it still has the white lines.
You could try twisting the lens if it twists. My webcams twist to adjust the picture. It's just a suggestion i don't know if that will work or not. If i helped you please leave me a rating.
Mar 03, 2010 | Logitech Webcam
Will a Logitech C500 Webcam work with an newer Mac Mini ?
UNIQUEMENT AVEC QT PRO, LES TYPES DE BEST BUY N'Y CONNAISSENT ABSOLUMENT RIEN!!!
The Logitech article on UVC lists the C500 as a supported camera, but also says:
"NOTE: With the exception of the QuickCam Vision Pro for Mac, all other UVC cameras are not officially supported on the Mac and some features or application support may not work."
Product ID: 0x0807
Vendor ID: 0x046d (Logitech Inc.)
Version: 0.09
Serial Number: F68AC850
Speed: Up to 480 Mb/sec
Jan 31, 2010 | Logitech QuickCam Communicate STX Personal...
Says already in use . to unplug usb port n re-plug in but same thing happens and i cant find where to turn the cam off.
I suggest you uninstall and reinstall the webcam drivers once again from the disc provided to you.And this time switch to another USB port.
let me know the result.
Thank you for using fixya
Dec 19, 2009 | Logitech Webcam
Lightwave LW-IC500 webcam. I cant get it to work
i have a driver here for your webcam. but you can download from internet. email me if not available romsky79@yahoo.com or chat me.
May 27, 2009 | Logitech QuickCam Webcam for Notebooks...
Says no driver for webcam
Hey,
Here you have logitech drivers for all the models. Just select your model and you can download the appropriate driver.
Hope this helps.
Thanks
Apr 15, 2009 | Logitech Webcam
Trying to install Logitech quickcam pro for notebooks onto a mac
To install your QuickCam Vision Pro on your Mac, simply plug in the Camera's USB cable into an available USB port on your mac. QuickCam Vision utilizes the built in Mac drivers so there are no additional software required to use your camera in most Macintosh applications. See also this
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/popup_adp.php?p_sid=VLmRiYmj&p_lva=8578&p_li=&p_faqid=6471&p_created=1176155953&p_sp=cF9zZWFyY2hfdGV4dD1MT0dJVEVDICBXSVRIIE1BQyZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfc29ydF9ieT0*
Jan 03, 2009 | Logitech QuickCam for Notebooks Pro...
I have a MAC MINI AND MY USB MIC IS NOT WORKING ON IT.
This product uses native driver support on a Mac. No Logitech Mac Software is available or required.
It should work instantly check your sound settings the mic might be on mute or your useing wrong input on your program.
Jan 14, 2008 | Logitech USB Desktop Consumer Microphone
Usb extention lead doesn't work with webcam
So you know the cam is ok and the cable, so you will have to point to the usb port not being able to push enough power through the cable to the camera as it must take a higher voltage than the other cam. Make sure that the other cam software is uninstalled and you have done registry clean in case of conflicts and also try using a different usb port but install the camera with the driver again using the extension in it, aplogies if you did, i am assuming you may have installed the camera directly without the extension cable.
Apr 29, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech Webcam Logo
124 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
