Question about Shure SM58 Professional Microphone
I'm using Audacity with a Shure SM58 mic, and the recording plays back fine when the mic is unplugged, but if it is still plugged in when I press Play, there is no sound and the light on the mic's chord blinks. Why is this??
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
I assume you are using the X2u USB adapter. When plugged in, the X2u acts as your sound card for recording and playback. Thus the playback will be on the headphone jack of the X2u. You can select which sound card to use for playback in the Windows Sound Control Panel.
Posted on Aug 06, 2010
Trouble with the Shure SM58 Mic.
Hi Ian,
i think the problem is with recorder or recording volume setting.
please check.
regards.
nuwan
Jan 10, 2014 | Toshiba Computers & Internet
Sm58 for speeches
Turn up the mixer, then it will be louder.
Apr 26, 2013 | Shure LX-2 With SM58 Professional...
Just got shure sm58, plug it into my starsinger on the tele but sounds is very low compared to the crappy mics? i plugged up a mixer box and can get more sound now but should it work fine with the...
The SM58 uses balanced output. If the starsinger uses a 1/4 inch jack, it is unbalanced input and probbly requires a high impedance rather than the low impedance SM58 mic. You can get an impedance transformer to fix that problem.
Dec 13, 2011 | Shure SM58 Professional Microphone
I have problems with my Lexicon u42s preamps. I use a dynamic Shure sm58 and on all the inputs it starts working only at almost end position of preamp regulator. Is it normal, or is there something wrong...
Dynamic mics such as the Shure SM58 require the input trim levels to be almost or at MAX setting... this is normal. Are you aware there are counterfeit SM58's being sold from sources on Ebay? Search Gooogle for info about this and how to tell the difference.
I don't know what the latentcy is since you have not told us what you are attempting or where you are seeing this. If you are converting (recording) and playing back at same time there will be a latentcy because unit has to convert, put in memory then convert the other direction. The latency from this is NORMAL. If the unit has a MONITOR function, it can just echo the input signal without converting while recording to avoid latency.
May 04, 2011 | Lexicon I ONIX U42S 4x2 USB 2.0 DESKTOP...
I have two Shure sm58 mics that simply will not work...I do not know where to begin. How should I trouble shot?
If these are wired SM58 mics, they will probably need to be sent to Shure for repairs. The cost to repair is less than purchasing a new one, and they will usually just send you a new mic.
Aug 28, 2010 | Shure SM58 Professional Microphone
Shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Apr 12, 2010 | Shure SM58 Professional Microphone
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
Where to buy a the swivel adapter for shure sm58 and shure wireless lx2 sm58
You can buy the swivels from Beyer, they have several sizes.
In my opinion he best you can get.
Regards,
Gerard
Jan 05, 2010 | Shure (LX287CC) Professional Microphone
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
Shure SM58 Professional Microphone Logo
215 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
